    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 962.6k Views 172 Watching
      alvin meza
      este plugin me presenta error en skp ya cargue las librerias y todo pero no me arranca
        this plugin presents me with an error in skp and I load the libraries and everything but it does not start
        Please post the error messages.
        Also ensure that your profile's details are up to date.
        Por favor, publique los mensajes de error.
        También asegúrese de que los detalles de su perfil están actualizados.
          RalfHannes
          it's not working for SketchUp 2019 😕
          Error when loading file C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb Error: #<IOError: The required, staged c extension file, "C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/libraries/stage/win64/2.5/msp_lib.so", is missing!> C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:inblock in require_all'
          C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in each' C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in require_all'
          C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main.rb:70:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require'
          C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require' C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in <top (required)>'
          C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in load'
          C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in register_extension' C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in module:MSPhysics'
          C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:5:in <top (required)>'
            If you look at the posts a few earlier you'll see that it's not compiled for the newer SketchUp version...
            Hence the error messages ?
              RalfHannes
              oh, i am sorry! thanks for your reply.
                ripvansparky
                Dang, just paid $300 so I could use this one extension, but it doesn't work with version 2019. Does anyone have any similar suggestions, or a way to create hinge points in a drawing? Thanks
                  I'm sure a v2019 compatible version is under development...
                  In the meanwhile you could get v2017 [Make?] and try using it with that for your hinging work...
                  You can always use 'SaveAs' in a newer version model to get a v2017 SKP that's compatible...
                  https://www.sketchup.com/download/all
                    thedemoriliza
                    i'm trying to simulate gears and linkages and all my components just fall apart. it's like the joints are weak, and things gradually just start to wobble and fall apart. anyone know if there's a way to stop this? i dont want the joints to break. cheers 😃
                    • ecatiE Offline
                      ecati
                      If you share the .skp file, we may have better information about the problem you are talking about and we can help you.
                      • F Offline
                        Fokys
                        Please tell me how to configure the plugin
                        How to stabilize objects moving in a closed circle ?
If there are a lot of objects (ball, cylinder, cube) on a closed line, they move not strictly along the center of the line, but slightly coming off in different directions from it
                        Sometimes objects are collected in one pile
                        Changed settings, but little helps
                          diogobr
                          My sketchup is hiding the objects, when I press start emulation (about 10 seconds). What is happening?
                            Ahmed0007
                            please update for SU2019
                              Anton_S
                              This happens because some objects, like hidden objects fall too far down to the point where your view is clipped. Ensure to assign an Ignore state to the that objects that should not be a part of simulation.
                                Anton_S
                                I will try to make the slider joint more useful by the next release. Thank you for your report!
                                  Anton_S
                                  I am on it!
                                    Ahmed0007
                                    @anton_s said:
                                    I am on it!
                                    Thank you so much
                                    • F Offline
                                      faust07
                                      Sounds good. This could be a reason to purchase SketchUp 2019...
                                        steambuf
                                        been looking for an animator for some time and have looked at this plugin with Sketchup 2017 Make to keep the costs down to zero. The new version of Free Sketchup is on line only so no use to me.
                                        I cannot get the joints to remain located exactly and the objects drift apart after a short period of time.
                                        I also downloaded a steam beam engine model with full animation. this worked fine for a couple of iterations and then proceeded to disintegrate due to drifting of the joints.
                                        Is this just me of is this an ongoing problem with this plug in?
                                        If I could get it to work it would be a terrific program. everything seems to work except this drifting of the joints. pity I've spent quite a bit of time trying to make it work.
                                          Anton_S
                                          @steambuf Yes, joints are a problem. I wm hoping that an updated version of nrwton dynamics physics engine addresses the problem. In the meantime, joint stiffness is best, if all connected bodies are of the same mass and solver model is set to itetative 64 passes. To change the mass of a body, use the UI.
                                            steambuf
                                            Thanks for the reply.
                                            Much appreciated!!
                                            Will play with it a bit more and try your suggestions. I really love what you are doing to keep the fun in programming and sharing your knowledge and skill with others.
                                            I'm now retired and trying to keep my brain active and you are helping me do that.
                                            Thanks again and would love to see an update to the non sticky joints???
                                            Cheers Peter
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 42 / 47
