    VRay 2.0 - SketchUp 2014
    renderpluginsextensions
    15 Posts 8 Posters 28.5k Views 8 Watching
      coreymurray
      Hi all
      Has anyone successfully installed VfSU 2.0 with SU2014?
      I'm assuming the problem is location change of plugins folder, but was wondering if anyone had anything definitive to say before i start hacking?!
      Cheers
      Corey
      • andybotA Offline
        andybot
        there's an update to vfs 2.0 "coming soon" to enable 2014 installation. Best to wait for that.
          coreymurray
          Copy that Andybot - Cheers ☺
          • murinaM Offline
            murina
            Hi everyone
            is there a way to install vray2.0 to Sketchup 2014?
            I upgraded, so I'm in big problem now if I can't render πŸ˜•
            podrum studios
            • dkendigD Offline
              dkendig
              a service release will be published on our website in the next couple of days to address 2014 support, as well as some other issues that were present in the 2.0 release.
              Devin Kendig
              Developer
              • dkendigD Offline
                dkendig
                @coreymurray said:
                Hi all
                Cheers
                Corey
                Actually, they changed the version of Ruby that is used in SketchUp 2014, which should break compatibility for a lot of plugins.
                Devin Kendig
                Developer
                • BoxB Offline
                  You should still be able to use 2013
                  • murinaM Offline
                    murina
                    Thanks for answers
                    Can I install 2013 and 2014 with same key?
                    (Purchased 2014 few days ago)
                    edit: internet says yes, so ill try
                    podrum studios
                      shoopa
                      will it be possible to release vray 3.0 core for sketchup2014?
                      WHY IS SKETCHUP COMMUNITY ALWAYS 2 STEPS BEHIND MAX etc. USERS?
                      /f.e. You put proxy in new vray for su, but still its better to do the vrmesh in max - its lighter this way....
                      OR...HOW MUCH ADESK IS PAYING YOU FOR THE DELAY`s WITH CURRENT VRAY RELEASES FOR SU?
                        timmyd2283
                        so, does it mean we cant use vray 1.6 in sketchup 2014?
                        • dkendigD Offline
                          dkendig
                          shoopa -
                          short answer, no, probably not.
                          There are many features that SketchUp lacks, which make it nearly impossible to support certain features of V-Ray. Prime example of just how behind SketchUp is... they don't have any concept of what a light is... or even better... what a mesh/object is. I understand the frustration, but our goal is to match the V-Ray for Max release as much as possible. In the past year we have hired more developers, testers, and have made some decent strides towards a more stable and feature packed product.
                          If you're referring to the time it takes to generate a proxy, that has been addressed in the pending service release.
                          ROFL
                          Devin Kendig
                          Developer
                          • dkendigD Offline
                            dkendig
                            timmyd2283-
                            Correct, but since there is no legitimate 1.6 version, and only expired beta/demo versions of 1.6 which give you watermarks, you will be able to continue getting watermarked renders with the 2.0 service release demo for SketchUp 2014, which will be available on our site in the next couple of days.
                            Devin Kendig
                            Developer
                              coreymurray
                              So..... a week later. Hows that service release going?
                              • dkendigD Offline
                                dkendig
                                well if people would stop trying to hack our website, that would help... Not sure if you saw this notice at the top of the Chaos Group website, but it says in bright red:
                                "Notice: We may have been the target of an attempted website breach. To be safe, all website passwords have been reset. You can reset your password here."
                                Look guys... I know you want this service release, but trying to hack our website isn't going to speed things along πŸ˜‰
                                Devin Kendig
                                Developer
                                • tt_suT Offline
                                  tt_su
                                  That's double-plus-ungood. 😞
                                  Hope you're back on track soon!
