    โš ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
    SketchUp 2014
    205 Posts 79 Posters 39.3k Views 79 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      I'll bet it is a plugin causing the instability.
      I'm not here much anymore.
        Have you tried running it with all Plugins/Extensions disabled ?
        Still get issues ?
        What do you have loading ??
        • xiombargX Offline
          xiombarg
          I had a minor issue when it was first released, which thanks to TIG was solved quickly, but since then I haven't had any problems at all. Stability has been solid so far.
          It would probably be good if Trimble started to recognize Sketchup as substantially more than an architectural program... but when you have plugin authors like Fredo, thomthom and TIG (and everyone else who has so generously donated their time and talents) it's making it quite easy to customize Sketchup to whatever kind of modelling software you want it to be.
            menes
            Hello everybody,
            one question sorry, going through of the posts here I could'nt find.
            Does SU2014 solved the problem with 64 bit OS previews ?
            thanks
              No. SU2014 isn't 64bit.
              Plenty of discussions on that topic here. ๐Ÿ˜’
              • 7
              • 8
              • 9
              • 10
              • 11
              • 11 / 11
