    [PLUGIN]MITSUBA Render Exporter v1.5.0(20141109)
    102 Posts 18 Posters 197.7k Views 18 Watching
      driven
      I can trap the create_directory error by appending at line 269 in mitsuba_main.rb
      the serialisation never occurs from the plugin...
      system(commandline, ;out => ['/tmp/log.txt', 'a'], ;err => ['/tmp/log.txt', 'a'])
        tak2hata
        In my mac that occurs.
        Here is log.txt.
        2014-03-18 23;21;32.391 mtsimport[308;507] ApplePersistenceIgnoreState; Existing state will not be touched. New state will be written to /var/folders/v2/nc5st2054wvghywgtfrszpf00000gn/T/org.mitsuba.Mitsuba.savedState
        2014-03-18 23;21;32 INFO  main [converter.cpp;137] Beginning conversion ..
        2014-03-18 23;21;32 INFO  main [collada.cpp;1596] Loading "mitsuba_main.dae" ..
        2014-03-18 23;21;32 INFO  main [collada.cpp;1642] Importing materials ..
        2014-03-18 23;21;32 INFO  main [collada.cpp;1669] Importing scene ..
        2014-03-18 23;21;32 WARN  main [collada.cpp;1288] instance_geometry does not contain a <bind_material> element!
        2014-03-18 23;21;32 WARN  main [collada.cpp;615] Referenced material could not be found, substituting a diffuse BRDF.
        2014-03-18 23;21;32 INFO  main [collada.cpp;1680] Done, took 0.0s
        2014-03-18 23;21;32 INFO  main [mtsimport.cpp;156] Encountered 14 warnings -- please check the messages above for details.
        Finished conversion (took 60 ms)
        In Sketchup Ruby Console
        system(%Q{'/Applications/Mitsuba.app/Contents/MacOS/mtsimport' '/Applications/su_render/mitsuba_main.dae' '/Applications/su_render/mitsuba_main.xml'})
        this return False?
        by TAK2HATA
          driven
          Here is my log.txt. after 2 attempts
          2014-03-18 13;58;36 INFO  main [converter.cpp;127] Creating directory "textures" ..
          Caught a critical exception; boost;;filesystem;;create_directory; Permission denied; "textures"
          2014-03-18 14;22;09 INFO  main [converter.cpp;127] Creating directory "textures" ..
          this return False?
          YES it returns false
          and if you use this version, you get the same error as the log file in Ruby Console...
          %x(/Applications/Mitsuba.app/Contents/MacOS/mtsimport /Applications/su_render/mitsuba_main.dae /Applications/su_render/mitsuba_main.xml 2>&1)
          2014-03-18 14:42:03 INFO main [converter.cpp:127] Creating directory "textures" .. Caught a critical exception: boost::filesystem::create_directory: Permission denied: "textures"
            tak2hata
            I get this return.
            2014-03-18 23;58;34.268 mtsimport[472;507] ApplePersistenceIgnoreState; Existing state will not be touched. New state will be written to /var/folders/v2/nc5st2054wvghywgtfrszpf00000gn/T/org.mitsuba.Mitsuba.savedState
            2014-03-18 23;58;34 INFO  main [converter.cpp;137] Beginning conversion ..
            2014-03-18 23;58;34 INFO  main [collada.cpp;1596] Loading "mitsuba_main.dae" ..
            2014-03-18 23;58;34 INFO  main [collada.cpp;1642] Importing materials ..
            2014-03-18 23;58;34 INFO  main [collada.cpp;1669] Importing scene ..
            2014-03-18 23;58;34 WARN  main [collada.cpp;1288] instance_geometry does not contain a <bind_material> element!
            2014-03-18 23;58;34 WARN  main [collada.cpp;615] Referenced material could not be found, substituting a diffuse BRDF.
            2014-03-18 23;58;34 INFO  main [collada.cpp;1680] Done, took 0.0s
            2014-03-18 23;58;34 INFO  main [mtsimport.cpp;156] Encountered 16 warnings -- please check the messages above for details.
            Finished conversion (took 42 ms)
            Is this problem security permission?
            by TAK2HATA
              driven
              the problem seems to be the path from boost to the file not having the correct permissions, if that makes sense...
              As the folder is in the HD/Applications/ I have tried it at /tmp/, ~/Desktop, ~/Documents and in Plugins, all fail...
              my copy of boost lives in /usr/local/bin/include, but it's a symlink to homebrew/cellar so that my be the issue...
              not following symlink from ruby, I'll check it again from terminal...
                driven
                that returns
                dyld; Symbol not found; __cg_jpeg_resync_to_restart
                  Referenced from; /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                  Expected in; /usr/local/lib/libJPEG.dylib
                 in /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                Trace/BPT trap; 5
                  tak2hata
                  @driven said:
                  that returns
                  > Trace/BPT trap; 5
                  Avoiding this problem,
                  I will write the code for serialized mesh exporter in ruby.
                  Thanks.
                  by TAK2HATA
                    driven
                    Good idea, it's probably the best long term solution...
                    you can PM me if you want anything tested...
                    john
                      driven
                      I just had a thought and did some tests...
                      commandline tool need to modify .bashrc to point to python...
                      I don't use a .bashrc file, i use .bashprofile, so I created one under User/me/.bashrc and it's not written to...
                      where is your .bashrc located, and exactly what does it contain??
                      john
                        tak2hata
                        john
                        I search in my mac.
                        I found "bashrc" in "/private/etc"
                        it contains this.
                        # System-wide .bashrc file for interactive bash(1) shells.
                        if [ -z "$PS1" ]; then
                           return
                        fi
                        PS1='¥h;¥W ¥u¥$ '
                        # Make bash check its window size after a process completes
                        shopt -s checkwinsize
                        # Tell the terminal about the working directory at each prompt.
                        if [ "$TERM_PROGRAM" == "Apple_Terminal" ] && [ -z "$INSIDE_EMACS" ]; then
                            update_terminal_cwd() {
                                # Identify the directory using a "file;" scheme URL,
                                # including the host name to disambiguate local vs.
                                # remote connections. Percent-escape spaces.
                        	local SEARCH=' '
                        	local REPLACE='%20'
                        	local PWD_URL="file;//$HOSTNAME${PWD//$SEARCH/$REPLACE}"
                        	printf '¥e]7;%s¥a' "$PWD_URL"
                            PROMPT_COMMAND="update_terminal_cwd; $PROMPT_COMMAND"
                        fi
                        by TAK2HATA
                          driven
                          thanks for that,
                          I found a note in the 'Mitsuba' source repository that the .bashrc file was no longer written to, so their message-box needs updating.
                          It does seem to be a simple path issue, that halts the process...
                          I just can't find it.
                          I have a separate instal of 'boost', so it may be a version/path conflict when Mitsuba calls it from shell...
                          Mitsuba works with other .dae files when imported, and I have older scene files from a previous instal, that run after they are auto updated on loading...
                          I'll remove my copy of boost and see if that makes a difference...
                          john
                            driven
                            hi
                            got it working...
                            will need tidying...
                            line 264
                            			commandline = %Q{cd /Applications && Mitsuba.app/Contents/MacOS/mtsimport #{objfile.gsub(/\\/,'/')} #{xmlfile.gsub(/\\/,'/')}}
                            OSX 10.9.2 must be stricter about the context...
                            john
                              tak2hata
                              @driven said:
                              hi
                              got it working...
                              line 264
                              john
                              Hi,john.
                              Thanks!!!
                              I change that line.and I update this to v1.2.1.
                              I am very Happy.
                              Thank you very much!
                              by TAK2HATA
                                tak2hata
                                @sadyo said:
                                Mitsuba seem work fine on my Sketchup 2014-Windowc 8.1 64bit
                                But,
                                How to implementing the clipmap/2D object in Mitsuba ❓ ❓
                                http://s1.postimg.org/jtfu9opfj/image.jpg
                                it won't appear in Renderer
                                Hi sadyo.
                                This problem is still exists.
                                if it is clip mapped material ,please use mask option in "OTHER" tab of material editor.
                                But the Image object is not material.
                                So it can not edit by material editor.
                                Please explode it to face and material.
                                The image object is no supported in this plugin ,yet
                                It will support in future version.
                                But clipping of Image object will not be supported.
                                And other notice,mitsuba render can not read TIFF and PSD.
                                Thanks!
                                by TAK2HATA
                                  driven
                                  downloaded v1.2.1 and notice you left the log code in...
                                  not sure if it breaks PC's
                                  john
                                    tak2hata
                                    john
                                    Sorry.
                                    Now I deleted that log option.and updated.
                                    Thanks john!
                                    by TAK2HATA
                                      sergonavt
                                      ""sophi skin"" 😞((
                                      windows-7, 64-bit, SU-7.
                                        Does anyone have any genderal advice on installing mitsuba? I am getting a report that a dll is missing and installation stops. Basically I can find no proper install documentation. Thanks.
                                          driven
                                          @mike
                                          did you try either/both of these window.exe downloads?http://www.mitsuba-renderer.org/download.html
                                          maybe some machine specs would help us out, helping you...
                                          john
                                            Thanks John, I feel like a right muppet not including specs, not as if I do not know, please put it down to a muppet day. I have tried the 64 bit program from that site/location.
                                            Specs as in the attached image.
                                            NVIDIA graphics card 1gb vram. This is updated as of about 1 week ago for drivers.
                                            System Specs
                                            • 6
                                            • 2 / 6
