    Outliner
    4 Posts 3 Posters 571 Views 3 Watching
    • G
      Gerry mc
      I want to be able to change the order of my groups and components inside my outliner. I tried but unsuccessfully... It's not as clear as I hoped. I managed to screw things up inside the box that I'm working on fixing. Where can I go to get a better understanding about this?
      • K
        kaas
        The outliner is sorted in alphabetical order: 0-9, A-Z, a-z, components before groups (but if you name the component as well it sorts again).
        You can't sort it manually, it always sorts alphabetical. You can change the hierarchy by: 1) making subgroups -> move an object in the outliner to nest in another group
        2) changing it's name or first letter.
        You can see an example the way I use outliner all the time here: http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=52954%26amp;hilit=+outliner#p481656
        • TIGT
          ... and if you do drag/drop items in the Outliner you are effectively moving them of one context into another - as if you had Edited the Container, used Edit>Cut, exited the Edit-session and opened a new container and used Edit>Paste_In_Place.
          A sure fired way to muddle yourself up.
          BUT it's a good way to manage entities if you structure your model sensibly, using Groups/Components to separate geometry and Layers to control their visibility...
          • G
            Gerry mc
            Thank you
