    Cylinders intersecting at a corner
    6 Posts 5 Posters 441 Views 5 Watching
      timreger
      I want to have two equal diameter cylinders meeting at one end of each cylinder - to form a right angle corner joint.
      I can't seem to get it to work so any help appreciated.
      Tim
      • cottyC Offline
        cotty
        One way with intersection...
        (with not to small cylinders!)
        [screenr:3ajjha5z]hpNN[/screenr:3ajjha5z]
        my SketchUp gallery
        • jeff hammondJ Offline
          jeff hammond
          use the follow me tool
          if you need to separate the individual segments, select one side of it then Group it.. you can then move them apart.
          dotdotdot
            "Click the cursor on the Circle"
            more precicely : Click the cursor on the Surface's Circle! πŸ€“ πŸ˜‰
              Pilou, clicking on the face with the Follow Me tool works just fine.
                timreger
                Thanks for the tips.
                I will give them both a try.
                Tim
