π Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
Cylinders intersecting at a corner
I want to have two equal diameter cylinders meeting at one end of each cylinder - to form a right angle corner joint.
I can't seem to get it to work so any help appreciated.
Tim -
One way with intersection...
(with not to small cylinders!)[screenr:3ajjha5z]hpNN[/screenr:3ajjha5z]
use the follow me tool
if you need to separate the individual segments, select one side of it then Group it.. you can then move them apart.
"Click the cursor on the Circle"
more precicely : Click the cursor on the Surface's Circle!
Pilou, clicking on the face with the Follow Me tool works just fine.
Thanks for the tips.
I will give them both a try.
Tim
