    Vray render extent
    renderpluginsextensions
    2 Posts 2 Posters 487 Views 2 Watching
    • J
      JKrowiranda
      I'm having an issue with render extent. I've matched my model with a photo (it's not seen on screenshots, cause I deleted it). Now, when I want to render it, the camera view somehow changes regardless how I'll position it beforehand.
      Here are screenshots to explain better the problem.
      I've tried zooming it out, ofc, didn't help. Setting the output bigger didn't too anything either. It always comes out like in pic. 2.
      I'm helpless. I wasted 4 hours at work trying to figure it out.
      • jiminy-billy-bobJ
        jiminy-billy-bob
        I assume your scene is a 2D scene, coming from a photomatch?
        You can try 'Camera>Parallel Projection', then 'Camera>Perspective', then create a new scene. You should end up with a 3D scene with the same point of view. Vray should then handle it fine.
