    Problem with leaf mapping in render
    renderpluginsextensions
    8 Posts 3 Posters 907 Views 3 Watching
    • X Offline
      xpLoid
      Hi all, first sorry for my english level.So here it is i have a problem rendering *.3ds file in sketchup with v-ray.In view port after importing the model it seems like it should be,with its leaf clipped, but in render leafs stays in rectangles without clipping them into leaf shape.Thank you for your time!
      ![This is the situation im infront of.](/uploads/imported_attachments/2tC2_inrender.jpg "This is the situation im infront of.")
      • X Offline
        xpLoid
        Even my obj files are not rendereble, only when i export to v-ray proxy something apears on the screen.. that screenshot was exported and undo..
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          You need to tick "use texture color as transparency" in the diffuse of your leaf material.
          • X Offline
            xpLoid
            Thank you! it seems i was blind but now i see! πŸ˜„ thanks again
              jiminy-billy-bob
              I don't understand why this isn't ticked by default...
              • dkendigD Offline
                dkendig
                it is in 2.0
                Devin Kendig
                Developer
                  jiminy-billy-bob
                  Oh? Great!
                  • dkendigD Offline
                    dkendig
                    you could also hack the VRayPlugins.xml file to modify this setting in 1.49.01... but that's a little dangerous πŸ˜‰ BACK THE FILE UP, PRIOR TO MODIFICATION!!!
                    <parameter handler="default" label="Use color texture as transparency" listType="none" name="use_color_tex_alpha_as_transparency" type="bool">
                    <value>
                    false
                    </value>
                    <handlerinfo>
                    <tooltip>
                    Enable this if you wish to use the alpha from the color texture for transparency
                    </tooltip>
                    </handlerinfo>
                    </parameter>
                    just have to change the false to true
                    Devin Kendig
                    Developer
