    Render changes by camera angle
    renderpluginsextensions
    6 Posts 4 Posters 421 Views 4 Watching
    • I Offline
      idavidrose
      Hey guys.
      I tried to make a realistic pool but when i render it it wont show the reflection right.
      it depends on which angle i try to render my scene.
      when i render my scene from above it shows the water as it should be
      but when i render it from the sides it shows only part of it.
      it has nothing to do with caustics/sun settings.
      From the side
      From above
      • dkendigD Offline
        dkendig
        can you share the file?
        Devin Kendig
        Developer
        • I Offline
          idavidrose
          I cant upload the file it takes too long and chrome just crash lol
          it happens with files i downloaded and not just with the file i made
          • V Offline
            valerostudio
            1. Place your pool right at the RGB axis in SU
            2. Check your photon radius in your sun parameters, it could be too small. It looks like its getting cut off.
            • I Offline
              idavidrose
              it doesnt work
              • BoxB Offline
                If you are unable to upload the file then there must be something wrong with it. It looks like it is only 10 faces, and the textures are simple it should be a tiny file size.
                If you have huge amounts of stuff hiding in the file it can cause problems. Purge everything from the file and try to upload it again.
