    Make active face the current layer
    6 Posts 4 Posters 1.1k Views 4 Watching
    • J
      jlyon
      Is there a quicker way to set the current layer than selecting it through the layer dialogue box? Sure would be nice to have a context menu item like "make layer current" when right-clicking a face.
      • TIGT
        Why are you changing the active-layer from Layer0 ?
        Drawing geometry on multiple layers leads to terrible confusion as deleting an edge from a visible layer can also remove an associated face on a hidden layer.
        Remember that Layers in SketchUp do not work like CAD layers.
        They do not separate geometry, they simply control the visibility of things.
        So grouped/component geometry can take another layer that switches on/off because the group/component already separates its contents from other 'outside' geometry...
        You can assign a layer to selected objects [doing so for edges/faces is NOT recommended] by using Entity Info's Layer-drop-down, or with the Layers docked toolbar dropdown...
        Didier's 'Layer-Manager' toolset also has tools to match/change layers, set active etc... IF you must pursue that route...
        • JQLJ
          JQL
          Amen to TIG! Follow this rule and you'll save yourself a lot of trouble!
          www.casca.pt
          Visit us on facebook!
          • J
            jlyon
            Ah. I think I see the light. So it's best to draw everything on layer 0, then assign groups or components to an appropriate layer for visibility. Is that the idea?
            • JasonWDJ
              JasonWD
              Yup!
              Also make a style with "Color By Layer" ticked.. then you have a very visible idea of what is going on in complicated assemblies.
              SketchUp, Thea Render, Vectorworks PC and Mac - Full LayOut workflow Concept>Production
              • J
                jlyon
                Thanks for that tip. Makes a lot of sense.
