    Modeling this Ralph Pucci Chandelier
    27 Posts 7 Posters 1.5k Views 7 Watching
      toddakeson
      How might I go about modeling this chandelier? Thanks in advance for any help you can give!
        Texturing a squashed sphere with a .png would be quick and dirty
          toddakeson
          Thanks Rich! Yes, I tried that. Any idea how to apply a map across an entire sphere as opposed to applying a map to each individual tile on a sphere?
            Can you post your failed attempt? An image or file?
              toddakeson
              Here you go.
                toddakeson
                Complete mess. haha
                  Can you share the .png?
                    Is it seamless?
                      toddakeson
                      Here it is..
                        toddakeson
                        Any tips if I actually want to model the geometry?
                          That texture ain't seamless.
                          To model something this complex in SketchUp is not advised.
                          Try Rhino with Grasshopper
                            toddakeson
                            Is there any way to make the texture seamless? I imagine I could work it out in Photoshop?
                            • micioneM Offline
                              micione
                              A quick attempt:
                              Tools used:
                              Tools on surface (trace a path)
                              Tape Maker (to create a solid conical)
                              Artisan (Sub / sm)
                              • olisheaO Offline
                                olishea
                                You can make a seamless texture in photoshop using the offset technique but it can be hit or miss depending on the size and type of texture. Google photoshop seamless texture offset. Of course it is possible though.
                                I tried something similar to this a while back and almost went crazy. It's really quite difficult.
                                I would start with a truncated globe and make a rotation array around the volume. Use JPP (joint push pull) to add thickness and then subdivide with Artisan to make everything smooth.
                                If you model in segments then make a rotation array you can ensure the geometry is seamless.
                                honeycomb lamp thread...which kinda went off topic!
                                http://sketchucation.com/forums/viewtopic.php?f=333%26amp;t=50584
                                also a working model that may give you some ideas of how to tackle the issue in sketchup:
                                oli
                                  toddakeson
                                  Thank you Micione and Olishea for the great suggestions!
                                  • olisheaO Offline
                                    olishea
                                    I attempted the truncated globe idea but it doesn't work. I tried using a honeycomb to keep things simple. Once subdivided it keeps the edges straight which isn't what I wanted to achieve. It won't subdivide into a globe shape once I had draped the honeycomb over. 😑
                                    oli
                                      Getting to this is straight forward. It is the missing elements that require manual rework....lot's of it πŸ˜•
                                      • olisheaO Offline
                                        olishea
                                        How did you do that?! I can think of a few ways but they take a loooong time. Did you twist the globe and multi face offset? Deleting the inner parts etc...
                                        [edit] I managed to do it but it's by no means made up of quads. Messy mesh. 😞
                                        oli
                                          Vertex Tools with soft falloff and select the top vert and rotate...
                                          Pull a copy off one twister out blah blah blah...
                                          Blender takes about 3secs to do the same when using proportional editing for the translations
                                          • cottyC Offline
                                            cotty
                                            I think there is one basic element in there which you "only" have to position correctly...
                                            Pilou friendly file πŸ˜‰
                                            my SketchUp gallery
                                            • 1 / 2
