    Place stones - searching for a plugin
    4 Posts 3 Posters 485 Views 3 Watching
    • T
      toto ete
      Hello,
      is there a plugin that can help me to build up following image?
      regards
      http://i.imgur.com/1UfujnR.png
      • massimoM
        massimo Moderator
        Why you need a plugin for that? It would be quite easy building it with the rotate/array tool.
        • TIGT
          • T
            toto ete
            thanks for the help!
            i thought about building it with the oob-su http://oob-su.com/ but it can not build round things, or with jolrans Hatchfaces plugin 1.8. i will look into the texture way of doing it, but dont know if its working out, because i cant edit it flexibel enough.
