    Extrude plugin
    8 Posts 5 Posters 567 Views 5 Watching
      Macker
      Hey guys & girls,
      I'm just creating a site plan and have all the outlines of various fences, etc draped across it and am looking to extrude them all directly upwards by 1800mm - which should give me fences that follow the contours of the land - much like how the extrude in 3ds max works on an open spline.
      I was just wondering if anybody could point me in the direction of a plugin that does such a thing, should one exist? I have had a search, and whilst I've found some wonderful extrude plugins, none of them seem to do quite what i'm after.
      Many thanks in advance.
      Check out my blog @ http://macviz.blogspot.co.uk
      • massimoM Offline
        massimo Moderator
        Something like this?
        Use for example the "Vector Pushpull" tool of Fredo's Joint pushpull plugin.
          Macker
          Kind of, though I am working with basic lines, to create basic fences (thin, not solid), thus there is no face to select to extrude; only lines.
          • BoxB Offline
            Tig's Extrude edges by vector.
            • massimoM Offline
              massimo Moderator
              Ok something like this then.
              Use for example the "extrude lines along vector" tool of Didier Bur's projection tools.
                Macker
                Exactly. Thanks guys, I'll try and find those.
                  There are excellent search tools on SCF... and better ones within specific pages...
                  PluginStore > Search 'Extrude' ?
                  and 'Extrusion' and 'Loft' are also good search keys...
                  My Extrude Toolset and then there's also Fredo's CurviLoft do most of what you might hope for πŸ˜•
                  • cottyC Offline
                    cotty
                    You will find this funtionality in many plugins... e.g.
                    my SketchUp gallery
