    Vray keeps crashing and hanging
    renderpluginsextensions
    4 Posts 3 Posters 19.3k Views 3 Watching
      mubs24
      my vray 1.6 in sketchup 2013 pro continuously crashes after a long time of processing the render n some times produces renders with dark patches. please help
      one of the reports goes :
      [SettingsImageFilter] - Unknown image filter, setting ignored
      Preparing renderer...
      Preparing scene for rendering...
      [RenderView] startCameraTime=0.000000, endCameraTime=0.033333
      [RenderView] numCameraTMs=2, numFrames=1, frameSamples=2
      Creating bitmap manager
      Initializing built-in VFB.
      Preparing camera sampler.
      Preparing scene for frame...
      Compiling geometry...
      Preparing ray server.
      Initializing face build data.
      SDTree statistics:
      Total number of faces stored: 679998
      Max tree depth: 51
      Average tree depth: 25.288
      Number of tree nodes: 322377
      Number of tree faces: 2219024
      Number of tree leafs: 124066
      Average faces/leaf: 17.8858
      Memory usage: 44.78 MB
      Scene bounding box is [-5890.25,-2235.47,0]-[6138.5,6014.38,4377]
      Preparing direct light manager.
      Preparing global light manager.
      Irradiance sample size is 84 bytes
      Photon size is 56 bytes.
      Light cache sample size is 120 bytes.
      Building light cache.
      Tracing 250000 image samples for light cache in 1 passes.
      Setting up 1 thread(s)
      Light cache time interval is (0.000000, 0.000000)
      Threads completed
      Merging light cache passes.
      Light cache contains 13931 samples.
      Light cache samples collected; compiling lookup tree.
      Prefiltering light cache.
      1 interpolation maps registered
      Rendering interpolation maps with minRate=-5 and maxRate=-3
      Threads completed
      Threads completed
      Threads completed
      Calling endPass() on irradiance maps
      Calling prePassDone() on irradiance maps
      Image prepass completed.
      Rendering image.
      Threads completed
      Number of raycasts: 2815563
      Camera rays: 324412
      Shadow rays: 355486
      GI rays: 2229799
      Reflection rays: 0
      Refraction rays: 0
      Unshaded rays: 0
      Clearing global light manager.
      Clearing direct light manager.
      Clearing ray server.
      Clearing geometry.
      Number of intersectable primitives: 679998
      SD triangles: 679998
      MB triangles: 0
      Static primitives: 0
      Moving primitives: 0
      Infinite primitives: 0
      Clearing camera image sampler.
      Clearing camera sampler.
      Clearing DMC sampler.
      Clearing path sampler.
      Clearing color mapper.
      Cleaning up bitmap manager
      Starting DR 1
      dr host: 127.0.0.1:20211
      Connected to render host 127.0.0.1:20211
      Using 1 hosts for distributed rendering.
      Bitmap file "C:/Users/user/Documents/textures/rhino textures/Shingle_Roof_DT.png" loaded.
      Bitmap file "C:/Users/user/Documents/textures/vray/vismat_material_collection/Stone/Ledgestone Brown/Masonry.Stone.Ashlar.Random.Broken Coursed.bump.jpg" loaded.
      Bitmap file "C:/Users/user/Documents/textures/vray/vismat_material_collection/pavers/pavers_DISP.jpg" loaded.
      SDTree statistics:
      Total number of faces stored: 679165
      Max tree depth: 48
      Average tree depth: 24.8912
      Number of tree nodes: 338861
      Number of tree faces: 2268059
      Number of tree leafs: 130401
      Average faces/leaf: 17.393
      Memory usage: 44.97 MB
      Running RTEngine
      dark parts
      • dkendigD Offline
        dkendig
        how much memory is being used during the render process? If you are approaching 4gb of memory usage, the crash is probably due to running out of memory. If you have a 64bit operating system, there is a workaround that will allow you to render and use more than 4gb of ram: http://help.chaosgroup.com/vray/help/sketchup/150PB/distributed_rendering.htm#settings
        Devin Kendig
        Developer
          jvmaciel
          SDTree statistics:
          Max tree depth: 51
          Threads completed
          Threads completed
          Threads completed
          Threads completed
          Rendering image.
          Threads completed
          Camera rays: 324412
          Shadow rays: 355486
          GI rays: 2229799
          Reflection rays: 0
          Refraction rays: 0
          Unshaded rays: 0
          Clearing geometry.
          MB triangles: 0
          Starting DR 1
          SDTree statistics:
          Max tree depth: 48
          Running RTEngine
          Hi mubs24!
          would you resolved the dark patches in your render??
          This problem was happening with me... and i can't find solution 😞
          • dkendigD Offline
            dkendig
            this shouldn't be an issue in 2.0. If anyone is still using the outdated 1.6 BETA version, please upgrade to the latest release. 1.6 was a beta only, was buggy, and was not ready for commercial use.
            Devin Kendig
            Developer
