    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 178.1k Views 85 Watching
    • P Offline
      pgarmyn
      @bik said:
      1. I have a problem with the setting panel.
        When I click on the button to call the setting panel, nothing happens.
      2. And most of time I encounter a bug splat windows when I just click on "create" for a first Rich Section. The section become grey, and everything close.
      3. When I succeed to create one, I don't have a lot of color section choice, only wide stripes by default and Black (plain color)...
      1. You have to select a section plan or section group. The instructions are in the text field below, or read the pdf file in the first post.
      2. How big is your mode? Start without projection. For big projects, it is better to limit projection : with layers from scene, limited by distance... . Do not select any command after selecting the ´creaté button, until the Section panel is updated.
      3. Only one default material will be created and aplied after creation with the default settings. Please Read the instructions : pdf file included in the first post: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55072#p499865
      • shake1S Offline
        shake1
        Hi, this is a little bug
        win7/64
        Su 2015 3.331 x64
        • srxS Offline
          srx
          Today I found out that plugin has time limit. How to continue using it?
          www.saurus.rs
            agmgpro
            The same thing is happening with me... please help!
            • P Offline
              Petrroo
              Hi! Thank you so much for your work on this plugin. A very useful program.
              But at the moment really need Your help!
              Already addressed, but the message remained unanswered! Suddenly stopped working plugin RichSection. As I understand the network is a demo version that stops working after a certain period. Work on the Mac. Previously had no problems. And all of a sudden stopped working. Tried to reinstall - no help. The most interesting thing that is worth Parallels with the sketch for the Windows. Put the plugin in there - the same nonsense - lets not create a section. Open the file with a previously created sections RichSection - they are edited, but all are not created equal! Really need Your help, because the whole model was done with the expectation of making further using this plugin!!! Thank you!
              • G Offline
                Gliph
                Le plug-in ne fonctionne plus, apparement la version demo s'arrête au 2 juillet 2015. On paye où pour la "full version" ? 😮
                • romboutR Offline
                  rombout
                  Im trying this again on mac su make 2015, but nothing happens? is this a know issue, i did a quick search here but coulnt find any mac users...
                  i think i found the issue, its a license thing. Thought this one was for free 😄
                  RichSection: Time-limited FULL WORKING license
                  Expired at 2015-07-01 20:00:00 -0400 : [nil]
                  • cucsat2003C Offline
                    cucsat2003
                    @ pgarmyn:Sorry for a dumb question.
                    But I've installed RS plugin,and it's icons appeared,but I can't add rich section(first icon) anymore.When I hit the icon,there's no section appears like in your video.
                    I've read all comments in this topic but can't find solution.
                    Should you help me please?
                    This plugin seems so great and I can't wait to try it.
                      Dimitri972
                      I fixed time expired problem. Here it is:
                      http://www.mediafire.com/download/brjzmnqzbcv38fp/RichSectionv0.5.8FULLByDimitri.zip
                      Author was't answering question for months. I tried to fixing expired issue and fixed. If this isn't wanting thing in this forum, you can delete my post. I don't know forum rules.
                        bimbachi
                        @Dimitri972
                        I did try on my macbookpro skp 2015 , unfortunately it crached skp
                        • jim smithJ Offline
                          jim smith
                          I loaded Dimitri's fix to replace the expired files, re-booted SU opened a model, selected create section and got the section box to appear on the model. I haven't time to experiment with it but apparently it will at least open on a PC (I am running an ASUS pc with i7, 16GB).
                          I hope pgarmyn has not lost interest because of "skalp". I am sure many people would like the option to use this free plugin.
                          "Out of clutter find simplicity,
                          from discord find harmony,
                          In the middle of difficulty lies opportunity"
                          Albert Einstein
                            Dimitri972
                            Most of Skalp section materials are free on 3d warehouse. You can combine them with this plugin for amazing result. And don't forget to make group or component before taking section.
                            Actually this plugin is crashing in many situation but it is still usefull plugin.
                            • P Offline
                              piyanan
                              Hello any one
                              I install plugin for sketchup 2015-64 bit for windows and saw tool in sketchup is OK
                              then I click 1st tool is (Create RechSection)and I did my model it is notthing to happen.
                              and same other tool
                                lippo
                                Hi, I have unloaded the plugin, but I don't succeed in making him/it work... I make click on the icon it creates richsection and it doesn't happen anything. I use SUpro2015 64bit 😳 😳
                                  Mike8P
                                  It doesn´t seem to work on SketchUp 2015...
                                  Any issue?
                                    @Skalp
                                    2 trivial questions 😄
                                    Does the Skalp material can be used as normal material for any facades surfaces ?
                                    Does SKalp is existing in French ?
                                    • SkalpS Offline
                                      Skalp
                                      @pilou said:
                                      @Skalp
                                      Yes Skalp materials can be used like normal SketchUp materials.
                                      At this moment there isn't a French version. But we are working on translations at this moment.
                                      The Skalp Team
                                      Skalp
                                      http://www.skalp4sketchup.com
                                      • SkalpS Offline
                                        Skalp
                                        Skalp section materials are intended to be used with Skalp. Skalp materials are much more then just textures.
                                        The Skalp team
                                        Skalp
                                          antoinelepoutre
                                          does not work in SU2016 on WIN7
                                            Ader89
                                            Hi, I put this aap on my sketchup 2015, every bottom is working including the menus, but when i tried to use create richsection its don´t work, the section plane just don´t appear on screen, what can i do to solve it? the app ins´t compatible with sketchup 2015? Thanks
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 19 / 20
