    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 184.8k Views 85 Watching
      Petrroo
      Hi! Thank you so much for your work on this plugin. A very useful program.
      But at the moment really need Your help!
      Already addressed, but the message remained unanswered! Suddenly stopped working plugin RichSection. As I understand the network is a demo version that stops working after a certain period. Work on the Mac. Previously had no problems. And all of a sudden stopped working. Tried to reinstall - no help. The most interesting thing that is worth Parallels with the sketch for the Windows. Put the plugin in there - the same nonsense - lets not create a section. Open the file with a previously created sections RichSection - they are edited, but all are not created equal! Really need Your help, because the whole model was done with the expectation of making further using this plugin!!! Thank you!
        Gliph
        Le plug-in ne fonctionne plus, apparement la version demo s'arrête au 2 juillet 2015. On paye où pour la "full version" ? 😮
        • romboutR Offline
          rombout
          Im trying this again on mac su make 2015, but nothing happens? is this a know issue, i did a quick search here but coulnt find any mac users...
          i think i found the issue, its a license thing. Thought this one was for free 😄
          RichSection: Time-limited FULL WORKING license
          Expired at 2015-07-01 20:00:00 -0400 : [nil]
          • cucsat2003C Offline
            cucsat2003
            @ pgarmyn:Sorry for a dumb question.
            But I've installed RS plugin,and it's icons appeared,but I can't add rich section(first icon) anymore.When I hit the icon,there's no section appears like in your video.
            I've read all comments in this topic but can't find solution.
            Should you help me please?
            This plugin seems so great and I can't wait to try it.
              Dimitri972
              I fixed time expired problem. Here it is:
              http://www.mediafire.com/download/brjzmnqzbcv38fp/RichSectionv0.5.8FULLByDimitri.zip
              Author was't answering question for months. I tried to fixing expired issue and fixed. If this isn't wanting thing in this forum, you can delete my post. I don't know forum rules.
                bimbachi
                @Dimitri972
                I did try on my macbookpro skp 2015 , unfortunately it crached skp
                • jim smithJ Offline
                  jim smith
                  I loaded Dimitri's fix to replace the expired files, re-booted SU opened a model, selected create section and got the section box to appear on the model. I haven't time to experiment with it but apparently it will at least open on a PC (I am running an ASUS pc with i7, 16GB).
                  I hope pgarmyn has not lost interest because of "skalp". I am sure many people would like the option to use this free plugin.
                  "Out of clutter find simplicity,
                  from discord find harmony,
                  In the middle of difficulty lies opportunity"
                  Albert Einstein
                    Dimitri972
                    Most of Skalp section materials are free on 3d warehouse. You can combine them with this plugin for amazing result. And don't forget to make group or component before taking section.
                    Actually this plugin is crashing in many situation but it is still usefull plugin.
                      piyanan
                      Hello any one
                      I install plugin for sketchup 2015-64 bit for windows and saw tool in sketchup is OK
                      then I click 1st tool is (Create RechSection)and I did my model it is notthing to happen.
                      and same other tool
                        lippo
                        Hi, I have unloaded the plugin, but I don't succeed in making him/it work... I make click on the icon it creates richsection and it doesn't happen anything. I use SUpro2015 64bit 😳 😳
                          Mike8P
                          It doesn´t seem to work on SketchUp 2015...
                          Any issue?
                            @Skalp
                            2 trivial questions 😄
                            Does the Skalp material can be used as normal material for any facades surfaces ?
                            Does SKalp is existing in French ?
                            • SkalpS Offline
                              Skalp
                              @pilou said:
                              @Skalp
                              Yes Skalp materials can be used like normal SketchUp materials.
                              At this moment there isn't a French version. But we are working on translations at this moment.
                              The Skalp Team
                              Skalp
                              http://www.skalp4sketchup.com
                              • SkalpS Offline
                                Skalp
                                Skalp section materials are intended to be used with Skalp. Skalp materials are much more then just textures.
                                The Skalp team
                                Skalp
                                  antoinelepoutre
                                  does not work in SU2016 on WIN7
                                    Ader89
                                    Hi, I put this aap on my sketchup 2015, every bottom is working including the menus, but when i tried to use create richsection its don´t work, the section plane just don´t appear on screen, what can i do to solve it? the app ins´t compatible with sketchup 2015? Thanks
                                    • romboutR Offline
                                      rombout
                                      It sort of works when im doing a single group, crashes when there is more than 1 though.
                                      osx 10.11.2
                                      su2015
                                      • E Offline
                                        Ekon
                                        I don´t get it to work properly on Win 10 and SU 2016 64bit pro. I get a simple section but no materials, no options dialog and if I do a second section it does it like native SU.
                                        None of the other buttons work. It says select Rich Section first, but my section is already selected.
                                        Some help would be appreciated.
                                        thanks
                                          RBCADDSVCS
                                          I've tried and tried to get this to work.
                                          I've installed, uninstalled, and reinstalled, and nothing works.
                                          I'm running Sketchup Pro 2014.
                                          The toolbars shows up, and the drop-down menu shows up, but when I click on them nothing happens at all.
                                          The log file says my license is expired.
                                          I didn't think it needed a license.
                                          What's up with that?
                                          • H Offline
                                            Haddal88
                                            Hello!
                                            I am trying this plugin after I saw the amazing videos.
                                            When I press the button to create the section, nothing happens.
                                            Running Pro trial on Sketchup 2017 Make.
                                            Any reasons?
                                            Running Windows 7, Intel i7.
                                            Thanks in advance!
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 19 / 20
