    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 213.9k Views 85 Watching
      kylintz
      I have the same problem like you agmgpro haha
        pgarmyn
        You can create as much scenes as you want, but, after scene creation, you will have to switch the section layer on, set section plan visibility ... and update the scene. 2 Scenes (in the settings) will come back, but i can't make 0.5.4 available because the data structure (for richsection information) saved in your file has changed.
        About crashing : what other plugins are you using?
          kylintz
          I think the crashing is caused by the #default material. On a fresh sketchup file, if i create a scene without applying #default rich section material to random object first, the sketchup would crash after creating rich section.
          And about the 2 scenes, I couldn't get it work. I couldn't make the option to create 2 scenes automaticaly for each rich section to work. There's only one option available on rich section setting for "Scenes created for each richsection" : Scene, sectionplan visible, no camera applied.
            pgarmyn
            @kylintz:
            Maybee my answer was not clear : the option for creation of 2 scenes doesn't exist in the latest version (it will come back). You can create yourself extra scenes as described before.
            About problems with loading #default : is the plugin installed in the default folder?
            To be able to help you, i need :
            If you switch on the ruby console : are there errors ?
            Please fill in your profile : windows version, Sketchup version ...
            • E Offline
              Esense3d
              Hello
              Itmakes sektions without Material ?
              Win 7 su 2015
              Thank you
                pgarmyn
                @esense3d:
                Did you tried without changing the parameters?
                  agmgpro
                  Thanks pgarmyn,
                  waiting then for 2 scenes to come back!
                  (it's possible for you to send me the older version via email??? If yes, my email is agmgpro@gmail.com)
                  Thanks again!
                    bik
                    I have a problem with the setting panel.
                    When I click on the button to call the setting panel, nothing happens.
                    (My Sketchup is the last one 15.3.331 64 bit)
                    And most of time I encounter a bug splat windows when I just click on "create" for a first Rich Section. The section become grey, and everything close.
                    An other information for you : When I succeed to create one, I don't have a lot of color section choice, only wide stripes by default and Black (plain color)...
                    I don't understand why I'm alone to have this problem.
                    I use sketchup for a professional need and I'm aware about how the sketchup plugins works.
                    I have tried to remove your plugin, and install again... But it's the same problem all the time.
                    If any conflicts, just look below. My only plugins installed are :
                    Sketchucation
                    Bezierspline
                    ExtrudeTools
                    PipeAlongPath
                    tt_cleanup
                    tt_material_replacer
                    Projection
                    jf_addlayer
                    Fredo6_RoundCorner
                    Mirror
                    If any idea ?
                      pgarmyn
                      @bik said:
                      1. I have a problem with the setting panel.
                      2. And most of time I encounter a bug splat windows when I just click on "create" for a first Rich Section. The section become grey, and everything close.
                      3. When I succeed to create one, I don't have a lot of color section choice, only wide stripes by default and Black (plain color)...
                      1. You have to select a section plan or section group. The instructions are in the text field below, or read the pdf file in the first post.
                      2. How big is your mode? Start without projection. For big projects, it is better to limit projection : with layers from scene, limited by distance... . Do not select any command after selecting the ´creaté button, until the Section panel is updated.
                      3. Only one default material will be created and aplied after creation with the default settings. Please Read the instructions : pdf file included in the first post: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55072#p499865
                      • shake1S Offline
                        shake1
                        Hi, this is a little bug
                        win7/64
                        Su 2015 3.331 x64
                        • srxS Offline
                          srx
                          Today I found out that plugin has time limit. How to continue using it?
                          www.saurus.rs
                            agmgpro
                            The same thing is happening with me... please help!
                              Petrroo
                              Hi! Thank you so much for your work on this plugin. A very useful program.
                              But at the moment really need Your help!
                              Already addressed, but the message remained unanswered! Suddenly stopped working plugin RichSection. As I understand the network is a demo version that stops working after a certain period. Work on the Mac. Previously had no problems. And all of a sudden stopped working. Tried to reinstall - no help. The most interesting thing that is worth Parallels with the sketch for the Windows. Put the plugin in there - the same nonsense - lets not create a section. Open the file with a previously created sections RichSection - they are edited, but all are not created equal! Really need Your help, because the whole model was done with the expectation of making further using this plugin!!! Thank you!
                                Gliph
                                Le plug-in ne fonctionne plus, apparement la version demo s'arrête au 2 juillet 2015. On paye où pour la "full version" ? 😮
                                • romboutR Offline
                                  rombout
                                  Im trying this again on mac su make 2015, but nothing happens? is this a know issue, i did a quick search here but coulnt find any mac users...
                                  i think i found the issue, its a license thing. Thought this one was for free 😄
                                  RichSection: Time-limited FULL WORKING license
                                  Expired at 2015-07-01 20:00:00 -0400 : [nil]
                                  • cucsat2003C Offline
                                    cucsat2003
                                    @ pgarmyn:Sorry for a dumb question.
                                    But I've installed RS plugin,and it's icons appeared,but I can't add rich section(first icon) anymore.When I hit the icon,there's no section appears like in your video.
                                    I've read all comments in this topic but can't find solution.
                                    Should you help me please?
                                    This plugin seems so great and I can't wait to try it.
                                      Dimitri972
                                      I fixed time expired problem. Here it is:
                                      http://www.mediafire.com/download/brjzmnqzbcv38fp/RichSectionv0.5.8FULLByDimitri.zip
                                      Author was't answering question for months. I tried to fixing expired issue and fixed. If this isn't wanting thing in this forum, you can delete my post. I don't know forum rules.
                                        bimbachi
                                        @Dimitri972
                                        I did try on my macbookpro skp 2015 , unfortunately it crached skp
                                        • jim smithJ Offline
                                          jim smith
                                          I loaded Dimitri's fix to replace the expired files, re-booted SU opened a model, selected create section and got the section box to appear on the model. I haven't time to experiment with it but apparently it will at least open on a PC (I am running an ASUS pc with i7, 16GB).
                                          I hope pgarmyn has not lost interest because of "skalp". I am sure many people would like the option to use this free plugin.
                                          "Out of clutter find simplicity,
                                          from discord find harmony,
                                          In the middle of difficulty lies opportunity"
                                          Albert Einstein
                                            Dimitri972
                                            Most of Skalp section materials are free on 3d warehouse. You can combine them with this plugin for amazing result. And don't forget to make group or component before taking section.
                                            Actually this plugin is crashing in many situation but it is still usefull plugin.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 19 / 20
