    Sketchup and Blender
    extensions
    170 Posts 26 Posters 48.6k Views 26 Watching
      Add an edge split modifier
        i'll rework the mesh for you.
        but please get out of the habit of n-gons in su....
        if you don't put that shit to bed then you'll never progress
        • soloS Offline
          solo
          Sketchup is pretty much ngons and tri's, I guess what you are saying is I need to model in Blender instead right?
          http://www.solos-art.com
            Not really....
            You need to think the same for both. It is about good topology.
            I do think you would benefit more in trying to model this in Blender then asking when you hit problems.
            I pretty much guarantee that how you model it in Blender will transition to SU. Proper topology means easier UV mapping.
            So either model it in SU with topology in mind or vice versa.
            • soloS Offline
              solo
              Can you show me how to model it in SU so that it translates better in Blender?
              • StinkieS Offline
                Stinkie
                Couldn't you bevel the n-gons in slightly in Blender to get rid of the smoothing issues?
                  Here's a very quick example....
                  • soloS Offline
                    solo
                    [attachment=0:314utpts]<!-- ia0 -->Image 1.png<!-- ia0 -->[/attachment:314utpts]
                    So what will it take to get a tutorial on how you did that?
                    And another thing, what software do folks use when doing a tutorial that shows what mouse and keyboard button is pressed?
                    • arail1A Offline
                      arail1
                      I think real important plugins when considering export to sub d are RemoveLonelyVertices or Vertex Tools. Even after you've thought through what the other program wants and modeled accordingly you can end up with a lot of tris because of hidden vertices at mid line positions in SketchUp (for instance when you had a polygon intersecting another polygon and then deleted the intersection)
                      Hope that helps in some way.
                        The reasons for learning Blender for me are numerous from animations, nurb modeling
                        Maybe I am wrong but seems Blender has not yet so many tools for nurbs ?
                        • soloS Offline
                          solo
                            Here's a good example why using n-gons in SU and then fixing them in Blender still causes havoc...
                            For modeling something like this logo you need to forward plan a small bit.
                            Both circles that meet in the middle must have a common amount of adjacent verts...
                            • soloS Offline
                              solo
                              Rich, So how would one use SU with Blender then going forward? What I mean is Sketchup even to be considered or should one just break the ties and go Blender 100%? As it seems that the mesh SU creates is pretty useless in Blender.
                                No, it's the habit that SU creates that is the problem.
                                Is is so easy to draw circles, have incorrect topology and create n-gons in SU that the user is pretty much learning a modeling approach that goes against every convention in every other app.
                                It is not to say SU is at fault it is that the user takes the lazy approach. Hence people whining that nothing is like SU and failing to step outside the comfort zone.
                                I model most of my Blender proxies in SU because it is quicker. I don't do detail work in SU though.
                                One of 2 things will happen here. You'll either have a Eureka moment or you'll just constantly flog SU into doing something it in't meant to do...
                                I've no problem helping out while you transition but I ain't investing time when I get the impression it is already proving too non-SU.
                                The reason I adopted Blender was I needed better animation tools. But months of 'why does this SU export cause this or that' meant the progress was slow. But now I know when to open S or when to open Blender.
                                I don't have a secret I just learned when to stop in SU and when to migrate models to Blender.
                                thea logo.skp
                                Here's what I would make in SU prior to Blender export for the sub-d work. Nothing anyone else couldn't do.
                                  dedmin
                                  About units in Blender - this is very confusing for new users:
                                  http://www.katsbits.com/tutorials/blender/metric-imperial-units.php
                                  Importing Google SketchUp files into Blender 3D - advanced:
                                  http://www.katsbits.com/tutorials/blender/import-google-sketchup-kmz-models-advanced.php
                                    dedmin
                                    • michaliszissiouM Offline
                                      michaliszissiou
                                      OK, joining the club.
                                      There are many reasons to turn a geometry to quads.
                                      SketchUp supports n-gons based geometry.
                                      Blender also supports n-gons.
                                      The way to import the SUp n-gons to blender and continue to be N-gons is the Collada format.
                                      Import in blender as collada then.
                                      Enter edit mode, select all (A), press W menu/[remove doubles], select all again, [ctrl+N], this will turn all normals of faces outwards , in case something messed up in SUp.
                                      Now you are ready to go for a nice UV unwrapping. No need to import textures from SUp (it is possible) because the SUp default unwrapping can be automatically generated in blender. It is the cubic projection.
                                      The blender UV editor is one of the more powerful around and I suggest you to learn it.
                                      Now, you re ready to setup a scene, lighting and go for a Cycles rendering.
                                      And, more additional modeling of course.
                                      • JQLJ Offline
                                        JQL
                                        I tried exporting a model from SU to render in Blender, with little success. Is there a way to export cameras from SU to Blender? That was mostly where I stuck because everything was already set in SU.
                                        Thanks,
                                        JQL
                                        www.casca.pt
                                        Visit us on facebook!
                                        • soloS Offline
                                          solo
                                          Thanks,
                                          JQL
                                          Looking at the addons in Blender there are many importers and exporters, I wonder what it will take or who it will take to write one for Sketchup, one that will support layers, groups, components, camera's and even animations.
                                          • soloS Offline
                                            solo
                                            My first attempt at following a tutorial.
                                            I changed the obstacle to the Thea logo and opted to render with the Thea plugin and not Cycles as Cycles was still rendering after 15 minutes (too slow) and Thea completed it in just over 3 minutes.
                                            • 8
                                            • 9
                                            • 2 / 9
