    Sketchup and Blender
    extensions
    170 Posts 26 Posters 49.9k Views 26 Watching
      @Pete
      Can the Thea logo be shared?
      Why is the tris a problem?
      What is it you want exactly to do with the mesh?
      • soloS Offline
        @rich o brien said:
        @Pete
        Yes, here it is:
        AutoSave_thea logo.skp
        I want to follow a Blender tutorial and finally render it with Thea4Blender, but I cannot get a smooth mesh in Blender in order to render and put materials on that I need.
          Are you setting the shading to smooth in the toolshelf?
          Whilst in object mode press T to show/hide toolshelf. Select the object and choose smooth for the shading
          • soloS Offline
            I tried that originally but looks ugly.
              Add an edge split modifier
                i'll rework the mesh for you.
                but please get out of the habit of n-gons in su....
                if you don't put that shit to bed then you'll never progress
                • soloS Offline
                  Sketchup is pretty much ngons and tri's, I guess what you are saying is I need to model in Blender instead right?
                    Not really....
                    You need to think the same for both. It is about good topology.
                    I do think you would benefit more in trying to model this in Blender then asking when you hit problems.
                    I pretty much guarantee that how you model it in Blender will transition to SU. Proper topology means easier UV mapping.
                    So either model it in SU with topology in mind or vice versa.
                    • soloS Offline
                      Can you show me how to model it in SU so that it translates better in Blender?
                      • StinkieS Offline
                        Stinkie
                        Couldn't you bevel the n-gons in slightly in Blender to get rid of the smoothing issues?
                          Here's a very quick example....
                          • soloS Offline
                            [attachment=0:314utpts]<!-- ia0 -->Image 1.png<!-- ia0 -->[/attachment:314utpts]
                            So what will it take to get a tutorial on how you did that?
                            And another thing, what software do folks use when doing a tutorial that shows what mouse and keyboard button is pressed?
                            • arail1A Offline
                              arail1
                              I think real important plugins when considering export to sub d are RemoveLonelyVertices or Vertex Tools. Even after you've thought through what the other program wants and modeled accordingly you can end up with a lot of tris because of hidden vertices at mid line positions in SketchUp (for instance when you had a polygon intersecting another polygon and then deleted the intersection)
                              Hope that helps in some way.
                                The reasons for learning Blender for me are numerous from animations, nurb modeling
                                Maybe I am wrong but seems Blender has not yet so many tools for nurbs ?
                                • soloS Offline
                                    Here's a good example why using n-gons in SU and then fixing them in Blender still causes havoc...
                                    For modeling something like this logo you need to forward plan a small bit.
                                    Both circles that meet in the middle must have a common amount of adjacent verts...
                                    • soloS Offline
                                      Rich, So how would one use SU with Blender then going forward? What I mean is Sketchup even to be considered or should one just break the ties and go Blender 100%? As it seems that the mesh SU creates is pretty useless in Blender.
                                        No, it's the habit that SU creates that is the problem.
                                        Is is so easy to draw circles, have incorrect topology and create n-gons in SU that the user is pretty much learning a modeling approach that goes against every convention in every other app.
                                        It is not to say SU is at fault it is that the user takes the lazy approach. Hence people whining that nothing is like SU and failing to step outside the comfort zone.
                                        I model most of my Blender proxies in SU because it is quicker. I don't do detail work in SU though.
                                        One of 2 things will happen here. You'll either have a Eureka moment or you'll just constantly flog SU into doing something it in't meant to do...
                                        I've no problem helping out while you transition but I ain't investing time when I get the impression it is already proving too non-SU.
                                        The reason I adopted Blender was I needed better animation tools. But months of 'why does this SU export cause this or that' meant the progress was slow. But now I know when to open S or when to open Blender.
                                        I don't have a secret I just learned when to stop in SU and when to migrate models to Blender.
                                        thea logo.skp
                                        Here's what I would make in SU prior to Blender export for the sub-d work. Nothing anyone else couldn't do.
                                          dedmin
                                          About units in Blender - this is very confusing for new users:
                                          http://www.katsbits.com/tutorials/blender/metric-imperial-units.php
                                          Importing Google SketchUp files into Blender 3D - advanced:
                                          http://www.katsbits.com/tutorials/blender/import-google-sketchup-kmz-models-advanced.php
                                            dedmin
                                            • 2 / 9
