    Moving geometry/text
    layout
    3 Posts 3 Posters 643 Views 3 Watching
    • Epix3DE
      Epix3D
      When I try moving geometry or text in LayOut it moves in a jumpy behavor snapping to invisible points. Is there a way to move freely without the snapping?
      Another problem I have is when resizing an imported view. Usually when I reduce the view from one side it moves the geometry with it when what I want is to clip the frame. Is there a way to pan inside the view to center the geometry?
        If you right click the canvas is grid snap or object snap enabled?
          You're getting the snapping to an apparent grid because that's what you have it set to do. Untick Grid Snap and it won't do that.
          If you want to adjust the viewport size without adjusting the size of the model, tick the box for Preserve scale on resize. Leave it ticked for that viewport or it will resize when you untick it.
