    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 949.5k Views 155 Watching
    • fredo6F
      fredo6
      You definitely have a problem with installation of LibFredo6 6.3.
      Where does this file "libfredo6.rb" comes from ?
      I mean C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/libfredo6.rb
      Please delete it, and retry.
      • M
        mvsuriano
        Old library file! Removed and it works just fine. Thanks Fredo!
        • frankflafyF
          frankflafy
          is this compatible with sketchup 2015 32 bit? i cant make the plugin select the face.
            Yes. It is compatible.
            Why don't you post a sample SKP file that illustrates the problem you're having? Help us help you.
            • TIGT
              Should be compatible.
              Does it load properly ?
              Have you read and understood its usage/instructions ?
              Are there any error messages in the Ruby Console when you try to use it ?
              Have you installed the latest LibFredo ? You need to do this as well, and restart SketchUp...
              • BoxB
                Be sure you are doing it the right way, it is click and drag.
                • TIGT
                  That error message will be very useful to Fredo in establishing what's wrong...
                  Over to him... πŸ˜•
                  • frankflafyF
                    frankflafy
                    should i PM him?
                    • TIGT
                      You could, but Fredo regularly visits here, so he should see your post/plight soon...
                      • frankflafyF
                        frankflafy
                        Does it load properly ? Yes it load properly
                        Have you read and understood its usage/instructions ? i understand the usage, in older version of SU i used it everyday.
                        Have you installed the latest LibFredo ? I installed latest and restarted my SU.
                        I have delete the lib and reinstall. but it dont help.
                        -and yes, this is the error i found on my ruby console-
                        This when i load the plugin
                        Error; #<NoMethodError; undefined method `entityID' for #<Sketchup;;Model;0x9ee8468 @cache_file_name=nil>>
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/body_Lib6FacePicker.rb;791;in `selection_add_remove_faces'
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/body_Lib6FacePicker.rb;731;in `selection_initial'
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb;565;in `handle_initial_selection'
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb;514;in `activate'
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb;64;in `select_tool'
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb;64;in `action__mapping'
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb;133;in `call'
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb;133;in `launch_action'
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/bootstrap_JointPushPull.rb;81;in `launch_action'
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/bootstrap_JointPushPull.rb;128;in `block in declare_command'
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb;1080;in `call'
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb;1080;in `command_invoke'
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb;1062;in `block (2 levels) in build_config_commands'
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;1077;in `call'
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb;1077;in `block in add_command'
                        SketchUp;1;in `call'
                        This when i select the face
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/body_Lib6FacePicker.rb;744;in `selection_validate'
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/body_Lib6FacePicker.rb;622;in `selection_validate_if_add'
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb;676;in `selection_freeze_positions'
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb;1283;in `onLButtonDown'
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/body_Lib6FacePicker.rb;916;in `onLButtonUp'
                        C;/Users/Foxy/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb;1315;in `onLButtonUp'
                        Please Help. πŸŽ‰
                        • fredo6F
                          fredo6
                          @frankflafy
                          The error on <model>.entityID is very strange because in Sketchup this is valid (it returns "Model".
                          Do you get this error for a sepcific model or always?
                          Fredo
                          • tt_suT
                            tt_su
                            @fredo6 said:
                            @frankflafy
                            Fredo
                            Actually, this is Dynamic Component that adds that to the Model class. It adds a few methods to make the Model class blend with the regular Entity class.
                            The changes DC do to the SketchUp API classes makes sense - but unfortunately they where added as part of DC and not the API. So if DC is disabled they won't work.
                            I personally want them merged into the official API - though there are challenges as some of them are not ideal for the API, as they have some failing edge cases that was good enough for DC, but not for an API. Need to be careful to reduce breaking things. Hence it's not been done yet.
                            • frankflafyF
                              frankflafy
                              @fredo6 said:
                              @frankflafy
                              Fredo
                              its fixed after i enabled the DC.
                              yes i disable the DC because of never used it. thanx for the respond.
                              • M
                                Marko87
                                Everytime I try to use Joint push pull, it freezes at 63 %.. Please help, I really need that tool for shape I'm working on it.. I'm using SU 15 pro. Thank you!!
                                • TIGT
                                  Do you mean by 'every time' - 'whatever I try to use it on [even the simplest box]...'
                                  OR do you mean - 'whenever I try to use it on a particular set of geometry...'
                                  First off, we must assume you have installed the latest version of this tool and the required Lib ??
                                  If it's the first problem, then something is up with either the way the tool is installed or you are trying to use it - as it works faultlessly for most of us.
                                  What settings etc are you using ?
                                  If it's the second problem, then there's probably something wrong with your geometry...
                                  Can you post a SKP of it so that we can check it out, and thereafter advise you more constructively...
                                  • josephkim626J
                                    josephkim626
                                    Feature Request.
                                    Hi, Fredo.
                                    I love your plugin, and have been using it very well for awhile now.
                                    Because of my workflow, there is a tiny feature request I would like to make if it isn't too difficult.
                                    Joint Push Pull
                                    Let me know if there is a way to produce the result that is shown on the right, as supposed to the one on the left.
                                    (Maybe there is a way, I suspect with "Borders" and different type of push-pull modes, but no luck so far)
                                    I would like two or more faces connected to be pushed all-together, but no edges created on the sides.
                                    Thank you in advance.
                                      You have just the line on the top and not on the bottom?
                                      Maybe you can use remove inner faces by Wikii ?
                                      And Clean Up by Thomthom on the selection of the Vertical + bottom faces ?
                                      Joint PushPull + Remove inner face + CleanUP = your exact result on the right! πŸ˜„
                                      ( here in Xray Mode)
                                      • BoxB
                                        Do you mean like this?
                                        • pbacotP
                                          looks like he also wants the original edge removed. Maybe a "too" special case? There are so many options in this tools as it is.
                                            Seems there is always a line on the bottom! πŸ˜‰
                                            he wants not ?
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 30
                                            • 31
                                            • 9 / 31
