    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 949.5k Views 155 Watching
    • TIGT
      @borgman said:
      By the by, I got this error when opening SketchUp. Does this help out?
      That is most likely because you have not updated to SketchUp v2014M1 which fixes a known issue.
      In SketchUp v2014M0 PC if you launch SketchUp by opening a SKP that is on a drive other than the drive where SketchUp.exe is located then it messes the S: list.
      Thus the Ruby2 stuff never gets loaded and tools like the SCFapi that rely on some functions fail.
      You should find that starting SketchUp from the menu and then opening a SKP does NOT create this issue.
      There is a fix rb file that went into Tools and sorted the $: out, BUT simply installing SketchUp v2014M1 is advisable, as it also fixes a few other glitches under the hood.
      • C
        cosmorobus
        not selected polygons. What's the problem?
        I have
        Fredo6_JointPushPull - v3.2b - 17 Mar 14
        LibFredo6_v6.0b
        Sketchup 14.0.4900
        • I
          interior_design
          It is really helpful in modeling which gives more precise and flexible design, indeed.
          Many thanks to the author: Fredo.
          • L
            littleche
            I have a problem with JointPushPull ...
            As you can see in the picture ,I can not pull this face Properly.
            The parts that I've marked with a green line ,JointPushPull is destroyed face .
            What can I do to fix this problem? ❓
            JP&P.skp
              Well, to start with, you've got some reversed faces. Instead of fixing them, you've tried to mask them by making the front and back faces the same color. That's not the right way to take care of the problem. Correct the face orientation and try again.
              Then try scaling up by maybe 100 to avoid smaller faces.
              • BoxB
                Apart from the reversed faces that Dave has pointed out, you have a layer other than Layer0 as the active layer, always keep 0 active, keep all raw geometry on Layer0 and only place groups or components on other layers. Also your linework is bad. Your edges are rough and don't form clean curves.
                  Indeed! And as is typical of computer stuff, GIGO applies here.
                  • BoxB
                    Just a couple of examples to show you what you need to fix.
                    This whole section is twisted
                    The red circle shows where the edge is kinked without any corresponding geometry.
                    • L
                      littleche
                      "Dave R" & "Box" Thanks for your help ...
                      revers and oriant face does not affect the performance of jointP&P plugin.
                      Yes, I agree my linework is bad but in bad line plugin good working !
                      I have tried many different ways But according to the your advice I still was not able to reach my goal.Another way to tell if it is possible ...
                      Is not this a bug in the plugin?
                        It would be nice to blame the plugin because your bad line work is causing the problem, wouldn't it? 😒
                        • BoxB
                          It's not a fault with the plugin, it is attempting to follow what you have drawn.
                          Get everything on the same layer and clean up your geometry and the plugin works.
                          I've no idea how you drew it in the first place but perhaps it would be easier to start again and get the geometry right rather than trying to repair it.
                          • L
                            littleche
                            This problem was solved! Thank you for your help ... my worklin was very bad .I got to practice tips that you said and Finally I drew a good workline with tools on surface plugin and jointpull&push It's nice to end. 😍
                            and Again, thanks ... 👍
                            • BoxB
                              Well done.
                              Learning to get your structure right in the first place is far better for you than getting a plugin to work.
                              • fredo6F
                                fredo6
                                NEW RELEASE: JointPush Pull Interactive v3.3a - 19 Oct 14
                                JointPushPull Interactive 3.3a is required for the support of usernames with non-ascii characters in Sketchup 2014
                                See main post of this thread for Download of JointPushPull.
                                Fredo
                                • M
                                  mvsuriano
                                  Hello - I've been using the old version of JPP for some time - its awesome. Recently tried to install the newest version via SketchUcation tools in SU 2014.
                                  I see the toolbar, however, clicking on any button/tool in the JPP toolbar doesn't do anything, it just defaults to the tool I had selected prior.
                                  Any suggestions?
                                  Thanks!
                                  Mike
                                  • cottyC
                                    cotty
                                    Any suggestions?
                                    Thanks!
                                    Mike
                                    Did you update LibFredo to version >=6.3? Are there error messages in the ruby console?
                                    my SketchUp gallery
                                    • fredo6F
                                      fredo6
                                      @mvsuriano,
                                      Could you open the Ruby Console before clicking on the JPP icon, in case there are error messages displayed
                                      Fredo
                                      • M
                                        mvsuriano
                                        @fredo6 said:
                                        @mvsuriano,
                                        Fredo
                                        HI Fredo - turns out I do have an error. I did update to FredoLib 6.3a prior to install. This is the error I get.
                                        Error: #<NameError: uninitialized constant G6::ShapeGrid>
                                        C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb:101:in initialize' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb:64:in new'
                                        C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull/JointPushPullTool.rb:64:in action__mapping' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:133:in call'
                                        C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:133:in launch_action' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull/bootstrap_JointPushPull.rb:81:in launch_action'
                                        C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_JointPushPull/bootstrap_JointPushPull.rb:128:in block in declare_command' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1080:in call'
                                        C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1080:in command_invoke' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1062:in block (2 levels) in build_config_commands'
                                        C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:1077:in call' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:1077:in block in add_command'
                                        -e:1:in `call'
                                          Try deleting the LibFredo6 files/folder from the Plugins folder and install the current version again. I had a problem due to some file not getting removed/overwritten when I installed the latest version. Deleting and installing fresh took care of it though.
                                          • M
                                            mvsuriano
                                            Just did a fresh install per your prompt, but still the same result:
                                            Error: #<NameError: uninitialized class variable @@lib_fredo_folder in LibFredo6>
                                            C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/libfredo6.rb:67:in folder' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:79:in use_single_library'
                                            C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:70:in block in use_libraries' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:70:in each'
                                            C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:70:in use_libraries' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1085:in usage_use'
                                            C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1079:in command_invoke' C:/Users/msuriano/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1062:in block (2 levels) in build_config_commands'
                                            -e:1:in `call'
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 30
                                            • 31
                                            • 8 / 31
