    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 949.6k Views 155 Watching
    • jujuJ
      juju
      @kawet said:
      I am a beginner in the use of Sketchup so maybe I did a bad manipulation, but for me, the installation of plugins JoinPushPull and Tools on Surface doesn't work (signature obsolete).
      The plugin vetting process put in place with SU2017 calls for signatures. Just because a plugin / extension shows "outdated signature" or "unsigned" doesn't mean it won't work, it only controls what is to be loaded. If you're super paranoid and have set up SU2017 to only load signed plugins / extenstions then trying to load an unsigned / out of dated signature plugin / extenstion won't work. However if your plugin / extension loading setup is unrestricted then these will load.
      • K
        Kawet
        Hi Juju,
        Thank you, i'm not ''super paranoid'', but i like to understand ... and its my first day on SU !
        Now i understand.
        ty
        • fredo6F
          fredo6
          @kawet said:
          Hi Fredo,
          Do you have an explanation?
          My version of SU is 17.1.173 and I'm on Mac.
          Thank you for your help.
          Kawet
          I will republish JPP with SU2017 certification.
          Fredo
          • jujuJ
            juju
            @kawet said:
            Hi Juju,
            Now i understand.
            ty
            There is nothing wrong with asking questions to understand. Anyhows, welcome to SketchUp! I must warn you, it is addictive!
            As long as you get your plugins from reputable sources you should not have problems with rogue plugins and, as such, be able to leave the plugin/extension loading settings to unrestricted.
            Happy Sketch(Up)ing!
            • shukritobiS
              shukritobi
              Hey Fredo,
              great tool! I've been using this plugin since 2 years ago. However, I've encountered a bug when trying to use JointPushPull.
              I was trying to extrude this plane:
              Date: 02-Feb-17 16:36:14
              An error occurred in Joint Push Pull
              Error in generation of the geometry
              undefined method `smooth?' for nil:NilClass
              JointPushPullGeometry.rb: 1107 -- block in geometry_coplanar_edges_overhang
              JointPushPullGeometry.rb: 1105 -- each
              JointPushPullGeometry.rb: 1105 -- each_with_index
              JointPushPullGeometry.rb: 1105 -- geometry_coplanar_edges_overhang
              JointPushPullGeometry.rb: 354 -- block in geometry_robot_erase_coplanar_edges
              JointPushPullGeometry.rb: 352 -- each
              JointPushPullGeometry.rb: 352 -- geometry_robot_erase_coplanar_edges
              JointPushPullGeometry.rb: 214 -- robot_call_action
              JointPushPullGeometry.rb: 177 -- geometry_robot_exec
              JointPushPullGeometry.rb: 160 -- geometry_robot
              JointPushPullGeometry.rb: 75 -- block in geometry_execute
              Lib6Operation.rb: 332 -- call
              Lib6Operation.rb: 332 -- step_geometry
              Lib6Operation.rb: 374 -- start_execution
              JointPushPullGeometry.rb: 75 -- geometry_execute
              JointPushPullTool.rb: 892 -- go_preview_or_geom
              JointPushPullTool.rb: 931 -- modify_execute
              JointPushPullTool.rb: 944 -- modify_offset
              JointPushPullTool.rb: 2081 -- action_from_VCB
              JointPushPullTool.rb: 2058 -- onUserText
              Here's the file: jpp error.skp
              I've encountered quite a number of errors, but today I decided want to learn more what's going on.
              • fredo6F
                fredo6
                @shukritobi
                Can you attach the model which has the bugs.
                The one you attached does not provoke errors, and is different from what you show on the picture.
                Fredo
                • fredo6F
                  fredo6
                  NEW RELEASE: JointPushPull Interactive v3.6a - 02 Feb 17
                  JointPushPull Interactive 3.6a is certified for SU2017 and includes a few bug fixing in the generation of geometry.
                  See main post of this thread for Download of JointPushPull.
                  Fredo
                  • R
                    Rafal76
                    I've just download the JointPushPull and LibFredo 6 but I don"t see the JointPushPull anywhere. I have Mac and I'm working with Sketchup 2017. Can somebody help me with that?
                    • TIGT
                      Have you installed the files from the RBZs ?
                      Have you restarted SketchUp ?
                      Have you looked in the Extensions Manager to see that they are both enabled ?
                      Have you look in the Toolbars etc... ?
                      • M
                        Maxym
                        Hey guys! I've installed the push/pull plugin, but the toolbar shows only J,V,N modifiers, and I can't find a configiration menu at all to add more tools, like X R and F..
                        I'm running Sketchup 2017, installed the lates version of the plugin and library, please advise!
                        • E
                          enbois
                          BonjourFredo6,
                          J'utilise actuellement SketchUp 8 free sous windows 10, depuis quelques temps déja et je suis très intéressé par trois de vos plugins que j'ai découverts par un tuto:
                          "Gratuit : Dessiner sa maison avec SketchUp de Denis Bolomier, tuto #49372"
                          J'ai essayé de télécharger les plugins "tools on surface", "joint push pull interactive"
                          et le libfredo6 5.9b au format rbz.
                          Je n'ai pas réussi à le faire car je n'ai pas trouvé l'endroit du téléchargement de ces plugins. L'anglais n'est pas ma langue habituelle, et le langage informatique non plus. Aussi si vous pouviez me donner le ou les liens pour télécharger, je vous en serais reconnaissant.
                          Bon et tant qu'à faire j'ai un deuxième problème: toujours dans le tutà cité au dessus, il est conseillé de télécharger "1001 bit tools". Ca c'est fait, il est installé, j'ai la barre des boutons mais quand je clique dessus il ne se passe rien. Je précise que j'ai bien coché la case "1001 bit tools" coché dans affichage/barre d'outils et qu'il apparait dans les "plugins" de mon SketchUp. Avez vous la solution pour remédier à ce problème? d'avance merci.
                          mon adresse mail: jeanclaude29mob@gmail.com
                          • K
                            kiimiiss01
                            Hi, I mostly use the vector push pull option, but i always have to set an interactivily custom direction so i can get the desire extrude.
                            So guys, is there a way i can bind a key (shortcut) to the interacctivily custom direction option.
                            The Idea is to work faster something like press V (open vector pushpull) then shift+v (set interactivily custom direction).
                            https://image.ibb.co/fvxf6F/qw.png
                            • S
                              snakeeyes
                              Thank you so much for this plugin, makes life easier
                                A curious bug 😄
                                If the "hole" is a component = bug
                                If the "hole" is not a component, that works!
                                hole_comp.skp
                                • I
                                  ifdesign
                                  Thanks a lot for plugin 😄)
                                  • E
                                    Eragon5454
                                    dehşet thnx
                                    • L
                                      LE1202
                                      thx for sharing
                                      • L
                                        LE1202
                                        where can I download ??
                                          First post of this thread for any info about download! 😉
                                          • R
                                            rv1974
                                            Fredo, firstly thank you for non-stopping support of your tools!
                                            1. FPP: Is it possible to enable snapping on 'chamfer zero' (gif #1)
                                              2.What causes this (gif #2) misbehavior of Follow PushPull?
                                            2. There were long happy times when user (via mouse movement) was setting the JPP's direction. Now its +- in VCB that ultimately rules (which is VERY counter-intuitive)
                                              Could you get back to the old style please?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 30
                                            • 31
                                            • 13 / 31
