    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 887.4k Views 155 Watching
    • fredo6F Offline
      @pixero
      Thanks for signaling. This seems to be an unusual case.
      Anyway, I have fixed the problem and will re-release soon.
        surfmike
        Hi. I'm having a problem with the plugin gui showing up really small in SU. See attached picture.
        I'm on SU2016, OS X 10.9.5.
        How can I make it bigger?
        //Mike
        it's small...
        • fredo6F Offline
          //Mike
          [attachment=0:26p179xb]<!-- ia0 -->Screen Shot 2016-11-26 at 11.35.17.png<!-- ia0 -->[/attachment:26p179xb]
          Mike,
          If you go to Windows > libFredo6 Settings... > Default Parameters..., you will find an option "Retina Screen" in the section "Palette Configuration".
          If you check the option, you should get the palette buttons bigger (x 2). However, the text may remain small.
          If you are OK, and since you are on SU2016, you can help me to see if we can resolve the issue, if you are OK to test some changes in the LibFredo6 library. I was hoping that it would be solved by Sketchup 2017, but that's not the case!
          Otherwise, other high-dpi screen users have discussed some ways to avoid the issue by system set up. See discussion here.
          Fredo6
          • pbacotP Offline
            What may I be doing wrong. Trying to pull up three surfaces sharing three edges.
            ate: 30-Nov-16 08:55:30
            An error occurred in Joint Push Pull
            Error in generation of the geometry
            Could not compute valid matrix from points
            JointPushPullGeometry.rb:: 1169 -- position_material
            JointPushPullGeometry.rb:: 1169 -- block in geometry_transfer_material_top
            JointPushPullGeometry.rb:: 1145 -- each
            JointPushPullGeometry.rb:: 1145 -- geometry_transfer_material_top
            JointPushPullGeometry.rb:: 337 -- block in geometry_robot_transfer_material
            JointPushPullGeometry.rb:: 337 -- each
            JointPushPullGeometry.rb:: 337 -- geometry_robot_transfer_material
            JointPushPullGeometry.rb:: 212 -- robot_call_action
            JointPushPullGeometry.rb:: 177 -- geometry_robot_exec
            JointPushPullGeometry.rb:: 160 -- geometry_robot
            JointPushPullGeometry.rb:: 75 -- block in geometry_execute
            Lib6Operation.rb:: 332 -- call
            Lib6Operation.rb:: 332 -- step_geometry
            Lib6Operation.rb:: 374 -- start_execution
            JointPushPullGeometry.rb:: 75 -- geometry_execute
            JointPushPullTool.rb:: 890 -- go_preview_or_geom
            JointPushPullTool.rb:: 696 -- dragging_stop
            JointPushPullTool.rb:: 1318 -- onLButtonUp
            • pbacotP Offline
              I guessed that although it looked simple, there might be some errant geometry from making the faces. I grouped the faces and ran TT Cleanup3 and that fixed it.
                surfmike
                //Mike
                [attachment=0:leehgwfs]<!-- ia0 -->Screen Shot 2016-11-26 at 11.35.17.png<!-- ia0 -->[/attachment:leehgwfs]
                Mike,
                Fredo6
                Hi Fredo,
                Sorry for late response.
                Tried it.
                The field/icons becme bigger.
                Still small text size.
                /Mike
                  Kawet
                  Hi Fredo,
                  I am a beginner in the use of Sketchup so maybe I did a bad manipulation, but for me, the installation of plugins JoinPushPull and Tools on Surface doesn't work (signature obsolete).
                  Do you have an explanation?
                  My version of SU is 17.1.173 and I'm on Mac.
                  Thank you for your help.
                  Kawet
                  • jujuJ Offline
                    juju
                    The plugin vetting process put in place with SU2017 calls for signatures. Just because a plugin / extension shows "outdated signature" or "unsigned" doesn't mean it won't work, it only controls what is to be loaded. If you're super paranoid and have set up SU2017 to only load signed plugins / extenstions then trying to load an unsigned / out of dated signature plugin / extenstion won't work. However if your plugin / extension loading setup is unrestricted then these will load.
                      Kawet
                      Hi Juju,
                      Thank you, i'm not ''super paranoid'', but i like to understand ... and its my first day on SU !
                      Now i understand.
                      ty
                      • fredo6F Offline
                        @kawet said:
                        Hi Fredo,
                        Kawet
                        I will republish JPP with SU2017 certification.
                        • jujuJ Offline
                          juju
                          @kawet said:
                          Hi Juju,
                          Now i understand.
                          ty
                          There is nothing wrong with asking questions to understand. Anyhows, welcome to SketchUp! I must warn you, it is addictive!
                          As long as you get your plugins from reputable sources you should not have problems with rogue plugins and, as such, be able to leave the plugin/extension loading settings to unrestricted.
                          Happy Sketch(Up)ing!
                          • shukritobiS Offline
                            shukritobi
                            Hey Fredo,
                            great tool! I've been using this plugin since 2 years ago. However, I've encountered a bug when trying to use JointPushPull.
                            I was trying to extrude this plane:
                            Date: 02-Feb-17 16:36:14
                            undefined method `smooth?' for nil:NilClass
                            JointPushPullGeometry.rb: 1107 -- block in geometry_coplanar_edges_overhang
                            JointPushPullGeometry.rb: 1105 -- each
                            JointPushPullGeometry.rb: 1105 -- each_with_index
                            JointPushPullGeometry.rb: 1105 -- geometry_coplanar_edges_overhang
                            JointPushPullGeometry.rb: 354 -- block in geometry_robot_erase_coplanar_edges
                            JointPushPullGeometry.rb: 352 -- each
                            JointPushPullGeometry.rb: 352 -- geometry_robot_erase_coplanar_edges
                            JointPushPullGeometry.rb: 214 -- robot_call_action
                            JointPushPullGeometry.rb: 177 -- geometry_robot_exec
                            JointPushPullGeometry.rb: 160 -- geometry_robot
                            JointPushPullGeometry.rb: 75 -- block in geometry_execute
                            Lib6Operation.rb: 332 -- call
                            Lib6Operation.rb: 332 -- step_geometry
                            Lib6Operation.rb: 374 -- start_execution
                            JointPushPullGeometry.rb: 75 -- geometry_execute
                            JointPushPullTool.rb: 892 -- go_preview_or_geom
                            JointPushPullTool.rb: 931 -- modify_execute
                            JointPushPullTool.rb: 944 -- modify_offset
                            JointPushPullTool.rb: 2081 -- action_from_VCB
                            JointPushPullTool.rb: 2058 -- onUserText
                            Here's the file: jpp error.skp
                            I've encountered quite a number of errors, but today I decided want to learn more what's going on.
                            • fredo6F Offline
                              @shukritobi
                              Can you attach the model which has the bugs.
                              The one you attached does not provoke errors, and is different from what you show on the picture.
                              • fredo6F Offline
                                NEW RELEASE: JointPushPull Interactive v3.6a - 02 Feb 17
                                JointPushPull Interactive 3.6a is certified for SU2017 and includes a few bug fixing in the generation of geometry.
                                See main post of this thread for Download of JointPushPull.
                                  Rafal76
                                  I've just download the JointPushPull and LibFredo 6 but I don"t see the JointPushPull anywhere. I have Mac and I'm working with Sketchup 2017. Can somebody help me with that?
                                  • TIGT Online
                                    Have you installed the files from the RBZs ?
                                    Have you restarted SketchUp ?
                                    Have you looked in the Extensions Manager to see that they are both enabled ?
                                    Have you look in the Toolbars etc... ?
                                      Maxym
                                      Hey guys! I've installed the push/pull plugin, but the toolbar shows only J,V,N modifiers, and I can't find a configiration menu at all to add more tools, like X R and F..
                                      I'm running Sketchup 2017, installed the lates version of the plugin and library, please advise!
                                      • E Offline
                                        enbois
                                        BonjourFredo6,
                                        J'utilise actuellement SketchUp 8 free sous windows 10, depuis quelques temps déja et je suis très intéressé par trois de vos plugins que j'ai découverts par un tuto:
                                        "Gratuit : Dessiner sa maison avec SketchUp de Denis Bolomier, tuto #49372"
                                        J'ai essayé de télécharger les plugins "tools on surface", "joint push pull interactive"
                                        et le libfredo6 5.9b au format rbz.
                                        Je n'ai pas réussi à le faire car je n'ai pas trouvé l'endroit du téléchargement de ces plugins. L'anglais n'est pas ma langue habituelle, et le langage informatique non plus. Aussi si vous pouviez me donner le ou les liens pour télécharger, je vous en serais reconnaissant.
                                        Bon et tant qu'à faire j'ai un deuxième problème: toujours dans le tutà cité au dessus, il est conseillé de télécharger "1001 bit tools". Ca c'est fait, il est installé, j'ai la barre des boutons mais quand je clique dessus il ne se passe rien. Je précise que j'ai bien coché la case "1001 bit tools" coché dans affichage/barre d'outils et qu'il apparait dans les "plugins" de mon SketchUp. Avez vous la solution pour remédier à ce problème? d'avance merci.
                                        mon adresse mail: jeanclaude29mob@gmail.com
                                          kiimiiss01
                                          Hi, I mostly use the vector push pull option, but i always have to set an interactivily custom direction so i can get the desire extrude.
                                          So guys, is there a way i can bind a key (shortcut) to the interacctivily custom direction option.
                                          The Idea is to work faster something like press V (open vector pushpull) then shift+v (set interactivily custom direction).
                                          https://image.ibb.co/fvxf6F/qw.png
                                            snakeeyes
                                            Thank you so much for this plugin, makes life easier
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 30
                                            • 31
                                            • 13 / 31
