    How to make a stencil
    4 Posts 3 Posters 1.3k Views 3 Watching
    • W Offline
      WorstCases
      Hello.
      I have these pipes and want to weld them together. Yellow in green.
      Is there a way that I can make a stencil with sketchup, print it, put it on my "real" pipe and know exactly how to cut the hole?
      Thank you,
      WorstCases
        How about using Jim's unfold plugin to unfold the yellow pipe? Unfold.
        A quickie:
          Save the model at each step in case of problems !
          If the yellow-pipe [group] extends into the center of the green-pipe [group]...
          Edit the green-pipe group and select its surface main.
          Toggle View > Component Edit > Hide Rest of Model ON [this works on groups too]
          Right-click > context-menu > Intersect with Model
          The outline of the yellow-pipe should now appear as a patch 'etched' on the surface of the green-pipe.
          Select the patch's surface.
          If you want to remove it use Edit>Cut [to leave it in place Edit>Copy]
          Exit the group edit mode and back in the model Edit>Paste the clipboard's surface patch away from the rest.
          Make a copy
          There are several 'Unfold' tools around - check out Jim's 'Unfold' [Dave R already linked to it] OR there's also 'Flattery'...
          Switch View > Hidden Geometry > ON.
          Use your chosen 'unfolder' tool to flatten the patch's surface into a single flat form.
          Rotate the now flat patch so it lies on the ground.
          If you print a plan-view of the outline at full-size you should be able to wrap that paper copy around the real-world green-pipe to use as an outline for cutting a real-hole.
          Note how SketchUp's circles are segmented, so the printed patch will always be slightly smaller than the equivalent real-world hole, the fewer segments the bigger the difference - you probably want some tolerance to let to adjust the cut anyway...
          If you are going to insert the yellow-pipe into the new hole in the green-pipe you'll probably want to trim its end...
          To make the equivalent 'patch' for the yellow-pipe the operation is similar but this time working in the yellow-pipe group - also this time the copied 'patch' will need to be the majority of the yellow-pipe's surface - you 'unfold' the whole cylinder and wrap the printed version around the real-world yellow-pipe...
          • W Offline
            WorstCases
            Thank you very much!
            Will try soon.
            WorstCases
