    Glass Material Issue
    renderpluginsextensions
    2 Posts 2 Posters 382 Views 2 Watching
    • J
      joseark
      V-ray 1.49
      Sketchup Pro 8
      Greetings, i'm doing this "simple" interior scene, there is a blue glass division that showed somewhat fine in my tests, except for the part when some glasses rendered in a different blue. I figured it was because of the side of the plane where i added the material, so i decided to convert those planes into volume, push/pull and group and i created solid glasses, then the matterial would be apllied to all the faces (i thought). Now those windows render completelly transparent (no color blue) and no reflection, and i think no refraction, I foun that strange and actually i have no idea of how to solve that. i'll apreciate the feed back, and as always very grateful.
      Test, where the glass is rendered in different blues
      glasses are made as a solid group and the fog color didn't show up, also the reflection is very little.
      Test where i put 2 planes and a solid group, a plane is facing backwards (pink one) the blue one rendered as i should (it probably needs more reflection)
      • TedVitale_CGT
        TedVitale_CG
        Hi joseark,
        Could you post a link with your scene, I'm not sure why its doing that and If I can see how your material was created I might be able to help.
        Ted
        Ted Vitale
        Owner | Creative Director
        http://www.voxl.vision
