    Curviloft: temporary dialog
    5 Posts 3 Posters 463 Views 3 Watching
    • kuponoK Offline
      kupono
      Just installed 1.2d. After a while the menu disappears and a dialog labeled Curviloft: temporary appears and sits in the middle of the screen. When I exit the ruby and start it again, the dialog remains. I have to exit SU and reload for Curviloft to return to normal. After using it a while, the behavior returns. Fantastic tools though.
      Regards
        Did you install the latest LibFredo6 files, too?
        • fredo6F Offline
          fredo6
          @Kupono
          Could you open the Ruby console and report if there is an error message.
          Fredo
          • kuponoK Offline
            kupono
            No error that I can see. It happened this time using the skinning tool, but has happened in spline and path as well. I couldn't id a particular pattern when it occurs. It works fine until it doesn't.
            • fredo6F Offline
              fredo6
              Could you post or PM me the full error message (from the top)
              Also, I see a mention of jbb_layer_panels in the error message. So there may be a conflict there too.
              Fredo
