    Problems with renders
    renderpluginsextensions
    7 Posts 4 Posters 573 Views 4 Watching
    • izabelavictoriaI Offline
      izabelavictoria
      Hello πŸ˜„
      I have some problems with renders. Whatever the options I choose, there are always some marks on the final render. I attach an example together with this question. I don't know how to deal with this and would be greateful for any advice.
      Thank you
      vray render
      • V Offline
        valerostudio
        3 questions -
        1. What version of V-Ray
        2. How is your environment GI setup
        3. Show us your render settings.
          izabelavictoria
          Hello, I have Sketchup Pro 8 for Mac and V-Ray (1.49.01).
          First I loaded Default Setings. Then I set the settings like that:
          • Global Switches: I enabled Default Light
          • Camera: I put Shutter Speed to 30
          • Environment: I entered the "M" in the "GI COLOR" and in the list on the left I put "None". The Value of GI COLOR I put on 40
          • Color Mapping: I put Bright Multiplier on 0,35
            thegreek87
            Here is a useful tutorial from Nomeradona for getting rid of the 'splotches'
            http://sketchupvrayresources.blogspot.co.uk/2011/07/trick-removing-splotches-in-vray.html
            http://www.nicholasvaisey.co.uk/.
            • V Offline
              valerostudio
              In order to light an interior you will need some interior light sources or you get these splotches. I think most folks add IES lights combined with some rectangular lights in front of the windows to toss in some lighting. Fernando did a nice interior tutorial on Youtube.
              • V Offline
                valerostudio
                Also,
                Don't use emissive materials to light your scene. I suspect that is how your recessed cans are setup? Emissive doesnt work the same way a V-Ray Light Material works in Max. It can only be used as a way to make a material 'look' lit.
                  jackwatson
                  As well as the other suggestions, have you tried increasing the HSph subdivs (under the irradiance map rollout) to something like 80-150 to reduce the blotchiness?
