    [Plugin] LSS Zone
    22 Posts 11 Posters 8.1k Views 11 Watching
    • K
      kirill2008
      Small Announcement (29-Jan-2017)
      Note that currently there are no plans to continue development of a free version of LSS Zone extension so it is recommended look for some other alternatives to this extension with a similar functionality.
      ver. 1.2.1 beta
      Brief
      'LSS Zone' is an extension for Sketchup, which allows to create, store and manage information about rooms.
      Features
      • create geometric data carrier (so-called 'zone'), which stores identity, quantitative and descriptive information about a room
      • reshape and/or re-adjust properties of created 'zone' interactively any time later
      • manage entered information in a batch manner using 'Properties' dialog
      • create and attach labels
      • generate reports
      Installation
      Unzip archive contents to SketchUp 'Plugins' folder.
      Basic Usage Steps
      It is just a recommended workflow for entering and managing information about rooms in a SketchUp model using 'LSS Zone' extension:
      • create some zones using main tool dialog
      • copy geometrically identical zones using native SketchUp tools
      • adjust identity attributes of copied zones
      • attach labels
      • generate reports
      It is necessary to have more or less detailed model of a building before using 'LSS Zone'.
      OS Support
      WinXP, Win7
      SketchUp Support
      The extension was tested on SketchUp 2013.
      Extension's web-page.
      Ver. 1.0.0 Known Issues
      • error raises in case if creating zone of a zero height
      • grouping of string fields just adds new strings without any separator (see attachment)
      • 'List Template' dialog sometimes fail to refresh results of grouping/sorting properly
      Version 1.1 Demo
      New Features
      • 'Layers Toolbar' added
      • 'Filter Zones' dialog added
      • handling of three zone types added (room, box, flat)
      • icon pack for backward compatibility with previous versions of Sketchup added
        Fixes
      • 'List Template' dialog updates results after 'Query string' changes as expected
      • report generator display properly grouped string values in a zones' list now
      • proper handling of a zero height of a zone implemented
      • picking a floor face in a model with multiple identical component instances works well now
      Version 1.1.1
      New Features
      • floor, ceiling and walls cumulative area added to 'Properties' dialog
      • suppressing units in an active model now affects zone labels, list and properties representation
        Fixes
      • hang after applying new properties to a set of transformed zones removed
      • an error fixed in 'Attach Labels' dialog if a label has a length value measured in feet and inches (appeared in a model with feet and inches)
      Version 1.2.0
      New Features
      • automatic zone's contour tracing feature added
      • 'Settings' dialog added (it contains settings only for automatic tracing for now)
      • ability to list nested elements of zone group(s) added to zone's list generator
      • suppressing of area units now affects 'LSS Zone' tool dialog as well
      Fixes
      • 'List Template' dialog restores caret position properly after refreshing of query results
      • 'Floors count' property removed from 'LSS Zone' dialog, when 'room' zone type is active at an initial launch of a dialog (it is visible now only for 'box' zone type as intended)
      • SU crash after deleting a nodal point while 'LSS Zone' tool is active is fixed
      • custom attributes remain attached after zone's contour editing using 'LSS Zone' tool
      Version 1.2.1
      New Features
      • ability to switch all dialogs to a smaller font size added
      • layout of all web-dialogs is tableless now
      • it is possible to fold/unfold groups of settings inside dialogs
      • automatic adjustment of dialog's height added
      • 'Trace Contour' settings added to 'Properties' dialog (it is possible to set contour tracing options individually for selected zone using 'Properties' dialog, options inside 'Settings' dialog affect new zone only)
      • adjustment of an initial position of zone's label added
      • persistence of zone's label position added (it is possible to move label manually after attaching and label will stay at the same position after rebuilding of a zone)
      • eye-droppers of 'LSS Zone' main tool dialog now pick visible material of a face (tool checks if front surface or back surface of a face is under cursor and returns face.material or face.back_material depended on check result)
      • 'LSS Zone' extension is made compatible with SketchUp 2014
      Fixes
      • pressing of an 'eye-dropper' button of 'Zone Tool' dialog now unpresses other 'eye-dropper' buttons in case if they were pressed
      • label template now processes well all characters
      • contour tracing now traces contours made of instances of the same component definition/group
      • deleting of an attribute dictionary in 'Properties' dialog now handles the situation when there are not only zone objects in current selection set
        @kirill
        Great plugin.
        • K
          kirill2008
          @rich o brien said:
          @kirill
          Great plugin.
          Thanks! ☀
          • S
            seasdes
            Looks like a great plugin. Would it be possible for the length of each side of the polygon to be displayed? It would then be a killer plugin.
            Using Sketchup Pro 2019
            • G
              glro
              congratulations... 👍
              for the enormous amount of work needed to produce such plugin and the video; it is very nice to watch, explains everything
              i agree with the latest comment: would it be possible to retrieve the surface of each room from the trace of the walls on the floor?
              • D
                dtrarch
                Very slick and useful extension. ☀
                Generous of you to share it too. 😄
                Thank you +++ 👍 👍
                dtr
                • takesh hT
                  takesh h
                  "Not sure about the practical purposes of this graph?"
                  I thought that that was a question, to which you'll give us an ingenious use of the graph later in the video, but it was a statement! 😲
                  kirill2008, I use your LSS Chrono all the time. I think it is a great plugin. Cannot thank you enough for that!
                  I haven't DLed this plugin yet but surely I will give it a try later.
                  The only issue I have with it so far is the way the plugin understands the floor area of rooms by tracing point by point. It's much easier if we can simply select the floor plane to designate the floor of rooms, don't you think?
                  X10 faster, sure!
                  • KrisidiousK
                    Krisidious
                    great plugin... would like to see Taesh's idea of using a plane for it.
                    By: Kristoff Rand
                    • K
                      kirill2008
                      Thanks to all for kind words!
                      That's right, this graph is only for aesthetic pleasure for now 😄 . There is no any practical utilization implemented for it in current version...
                      The point is that the ability to pick a floor face is actually already present in the current version. This feature wasn't demonstrated in a video (as well as some other interesting features).
                      I would like also to inform everyone about some issues, which were found recently almost immediately after publication:
                        Grouping of string fields
                      The mentioned issues will be fixed in the first minor update, which is scheduled in three nearest weeks.
                      • KrisidiousK
                        Krisidious
                        By: Kristoff Rand
                        • mitcorbM
                          mitcorb
                          The quick pick room floor area is a good request. All you have to solve is how to differentiate between the entire floor plate component or group and that of the room. Your demo of floor area tracing reminds me of the Autocad command "solid" for shading or filling a 2d area.(what an inept name?). Perhaps there is a "boundary seeking" function in Ruby that respects coincident group edges- or...
                          • K
                            kirill2008
                            Well that sounds challenging 👍
                            But actually my dream is to solve even more challenging task. The point is that tracing zones' contours is not that time consuming after all in contrast with tracing of openings. In addition to that, there is no clear way in current version to generate a zone of a room with sloped walls and/or ceiling (for now it is only possible to edit zone's elements manually and recalculate zone's quantitative attributes). So the question, that hunts me, is how to differentiate between room's internal space and an entire space outside a room. Besides it would be nice to be able to "fill" automatically an internal space of any possible complex topology (sloped or curved walls, floor, ceiling). Of course it will be necessary to detect and take in account somehow holes (openings) in bounding surfaces as well.
                            I'm afraid it might take a while to implement such logic, but I don't say it's impossible as a matter of principle 😄
                            • KrisidiousK
                              Krisidious
                              Mit, Just separate the rooms with a line and hide the line... I do it for flooring normally but even if it's the same for square footage.
                              By: Kristoff Rand
                              • srxS
                                srx
                                Besides automatic finding of areas, just one more thing - binding area geometry to structure. So if the structure was changed, areas are also changed 💚 ...just kidding... This is one small step for a man, but the huge lip for SU BIM! Thank you Kiril. 👍
                                (Manually I would derive it from existing geometry this way: select structure(walls, floor, ceiling), copy it far away, explode it, intersect with each other, select inner surfaces, make a groups on layers (walls, floor, ceiling), and move it back to the original location).
                                www.saurus.rs
                                • mitcorbM
                                  mitcorb
                                  I just remembered about Voronoi cells. Maybe this has some application in defining/seeking areas? But I don't know, didn't look for how any Voronoi operation would treat a region with a hole in it.
                                  • K
                                    kirill2008
                                    Sure why not 😄
                                    More seriously, I think that if automatic zone creation will be finally implemented somehow, then implementation of automatic refreshing of zones will be more or less easy to carry out.
                                    Thank you!
                                    Maybe I would rather say quite the opposite 😄 I mean, LSS Zone is not that big thing on the scale of Sketchupverse. This extension is a personal significant achievement (maybe), but it utilizes only one certain set of Sketchup's endless range of possibilities.
                                    Dealing with SU API may give some insights into Sketchup's thrilling nature. But the amount of methods is not the point, the point is the core ideology. Something done right in it 😄
                                    The only solution I can imagine for now is to ask a user to define somehow what to treat as a hole. Still have no clear idea how to do the rest logic though...
                                    • K
                                      kirill2008
                                      Small announcement: automatic contour tracing implementation is in progress now. Here is a preview of room's contour tracing process:
                                        Seems very useful for architecture! ☀
                                        • mitcorbM
                                          mitcorb
                                          Hi, Kirill:
                                          I like your latest innovation.
                                          • K
                                            kirill2008
                                            Thank you guys! ☀
                                            I would like to mention that I personally use this extension heavily for my own practical purposes (architectural design) so chances are it may be useful for other architects as well. At least I hope so 😄
                                            • 1 / 2
