    When You Decide to Quit SketchUp...
    11 Posts 9 Posters 1.2k Views 9 Watching
      ...you should get this:
      http://www.urbanarchaeology.com/images/product/salvage/main/Nike-Drafting-Table.jpg
      πŸ˜„
      • massimoM Offline
        massimo Moderator
        I still have one of these and use it sometimes. πŸ˜‰
        • BoxB Offline
          I thought you were going to suggest Crack as it's far less addictive.
            that's probably cheaper than the table I showed, too. πŸ˜†
              First image is something real or an 3D avatar ?
                It's a SketchUp model rendered in Kerkythea.
                Just kidding. It's real. This is from the source:
                Nike Hydraulics
                $19,500
                ca 1940
                steel and acrylic
                Swedish
                [i]"This restored drafting table was made by Nike Hydraulics
                in Eskilstuna, Sweden. The base, drawing arm and light
                are made from nickel plated steel and the base has a
                hydraulic mechanism. It pivots, angles and moves up and
                down to a minimum height of 5’ and a maximum of 5’-10”.
                It includes a drafting arm, adjustable light and a 41”x 60”
                acrylic top."
                • utilerU Offline
                  utiler
                  I love my drawing board! Will never give it up....
                  Just Curious...
                  • emerald15E Offline
                    emerald15
                    Snagged parallel motion, blocked Roterings, eraser bits everywhere, Pounce! COW GUM!!!... Ahh! happy days!
                    • GarethG Offline
                      Gareth
                      aaaaaaaah....those were the days
                      I have just recently moved into new office premises and it is a little smaller than my previous one.
                      Then, I had two Mutoh boards with adjustable parallel motions, I had to part with one of them when I moved. It was a sad day. I kept the other, not because I use it very often, but because it's like a security blanket, and it brings back fond memories of the skills of draughtsmanship.
                      • marked001M Offline
                        marked001
                        I have not drafted in probably 15 years. Definitely miss it.
                        Fun fact... the drawings for alot of tv/film sets (in NYC anyway) are still all hand drafted. I was shocked when I got into the biz and came across this. Some really impressive drawings skills too.
                        http://www.revision21vis.com
                        instagram: revi21on
                        • W Offline
                          watkins
                          I probably did some of my best work on the drawing board. One had to be economical with the views, unlike today's 3D modelling suites where views are generated by a mouse click.
                          Bob
