    Ceramic house
    33 Posts 16 Posters 2.6k Views 16 Watching
    • massimoM Offline
      massimo Moderator
      A funny reconstruction of a small apartment in Madrid by Héctor Ruiz-Velázquez in order to be used as a guesthouse for a ceramic producer company.
      Tested for the first time the new Thea's field mapping biased engine and I have to say that I'm pretty impressed by how it solved this quite complex scene.
      Never tried a biased engine before.
      "Interior fine" preset with increased tracing depth (up to 20) just for some materials.
      Apart from some furnitures and accessories, almost everything was modeled by me in Sketchup.
      Ibl + every kind of lights: spots, omni, ies and emitters.
      PS and magic bullet photolooks for the post pro. The images were also reduced.
      Sorry a lot of images, but it was entertaining moving the camera around. 😄
      • Rafferty94R Offline
        Rafferty94
        Really cool room! Enjoyed all the different shots
        • stefanqS Offline
          stefanq
          WOW! Thea is brilliant in the right hands!
          V-ray....be afraid....
          • Bryan KB Offline
            Wow. 😲
            Architectural magazine photo quality renders.
            • xonptX Offline
              xonpt
              very good
              but out of curiosity, could you tell us the average time it took to render? (and of course the original resolution and rendering power of your machine)
              i also think Thea 1.2 is amazing... its biased engine is almost as good as unbiased ones, but i find it much slower, in comparison to VRay 2.0
              so that's why i am curious to know your feedback about Theas biased speed
              anyway, the renders are great, thanks for sharing
              • alvisA Offline
                alvis
                It's amazing! What is the original size of the image? How long THEA rendering a single image?
                Hmm ... I never use "Interior fine" preset. It's a long process ...
                • RichardR Offline
                  Richard
                  Wow Massimo! Mate that is some seriously good stuff there mate! Not just from a rendering point, but some outstanding camera work! I'm truly IMPRESSED! 👍
                  [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                  • massimoM Offline
                    massimo Moderator
                    Thanks guys. 😄
                    The images were rendered at 1500X1043 px for 5-7 hrs each (depending on the scene) on my old i7 with 6 Gb of RAM.
                    Anyway you have to consider a couple of things:
                    -the scene is quite complex (a lot of geometry, reflective and SSS materials, lighting etc.) and there are also two omni inside the hanging lamps which shine through a frosted glass;
                    -I'm totally new to biased rendering settings, so I've picked the highest preset with no further tweaks. Just made some adjustment on single materials;
                    -the unbiased engines were almost unable to clean the scene in an acceptable time.
                    Yeah, I love wide angle lenses. Here I've used 14 or 20 mm.
                    • olisheaO Offline
                      olishea
                      This is probably some of the best work you've done!! Hats off! Yes camera work is truly excellent. There is something captivating with ceramics.
                      oli
                      • massimoM Offline
                        massimo Moderator
                        Thanks Oli, you're alwas very kind. 😄
                          Incredible.
                          • massimoM Offline
                            massimo Moderator
                            Thanks Rich, this time there are the electrical sockets... 😉
                            • xonptX Offline
                              xonpt
                              this is the only reason i dont switch to Thea... the unbiased engines are amazing, and now with the 1.2 final gathering, the biased ones are almost equally good
                              but i miss a biased preset where you can give up a little bit on quality, but get a render in 15 to 30 minutes, like you can do in VRay
                              even with "basic" interior preset, with no supersampling, i get 2 to 3 hour render in these kind of complex lightning scenes (my machine is even "older" than yours...)
                              but again, amazing images, you and Thea work very well together
                              • BoxB Offline
                                Simply Stunning work.
                                But I shudder to think what would happen if you dropped your coffee cup, the shrapnel would be lethal.
                                • massimoM Offline
                                  massimo Moderator
                                  Thanks for comments guys. 😄
                                  • GarethG Offline
                                    Gareth
                                    pffffft....not bad i suppose...!! 😆
                                    ok, ok...it's bloody good....!! 👍
                                    • massimoM Offline
                                      massimo Moderator
                                      Thanks. 😄
                                      • olisheaO Offline
                                        olishea
                                        what texture did you use for the specular massimo? Looks very real.
                                        oli
                                        • massimoM Offline
                                          massimo Moderator
                                          You mean for the ceramics?
                                            @rich o brien said:
                                            Incredible.
                                            Yes, looks like the place had a nice vacuuming before you took the photo.
                                            • 1 / 2
