    Ceramic house
    33 Posts 16 Posters 3.1k Views 16 Watching
    • massimoM Offline
      massimo Moderator
      Thanks Oli, you're alwas very kind. πŸ˜„
        Incredible.
        • massimoM Offline
          massimo Moderator
          Thanks Rich, this time there are the electrical sockets... πŸ˜‰
          • xonptX Offline
            xonpt
            @massimo said:
            The images were rendered at 1500X1043 px for 5-7 hrs each (depending on the scene) on my old i7 with 6 Gb of RAM.
            this is the only reason i dont switch to Thea... the unbiased engines are amazing, and now with the 1.2 final gathering, the biased ones are almost equally good
            but i miss a biased preset where you can give up a little bit on quality, but get a render in 15 to 30 minutes, like you can do in VRay
            even with "basic" interior preset, with no supersampling, i get 2 to 3 hour render in these kind of complex lightning scenes (my machine is even "older" than yours...)
            but again, amazing images, you and Thea work very well together
            • BoxB Offline
              Simply Stunning work.
              But I shudder to think what would happen if you dropped your coffee cup, the shrapnel would be lethal.
              • massimoM Offline
                massimo Moderator
                Thanks for comments guys. πŸ˜„
                • GarethG Offline
                  Gareth
                  pffffft....not bad i suppose...!! πŸ˜†
                  ok, ok...it's bloody good....!! πŸ‘
                  • massimoM Offline
                    massimo Moderator
                    ... πŸ˜›
                    Thanks. πŸ˜„
                    • olisheaO Offline
                      olishea
                      what texture did you use for the specular massimo? Looks very real.
                      oli
                      • massimoM Offline
                        massimo Moderator
                        You mean for the ceramics?
                          @rich o brien said:
                          Incredible.
                          Yes, looks like the place had a nice vacuuming before you took the photo.
                          • massimoM Offline
                            massimo Moderator
                            Nowadays you can use one of these anyway... πŸ˜›
                            • GarethG Offline
                              Gareth
                              @massimo said:
                              ... πŸ˜›
                              Thanks. πŸ˜„
                              you know i love it....!! πŸ˜†
                              • cheddaC Offline
                                chedda
                                Good job !
                                Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                                • massimoM Offline
                                  massimo Moderator
                                  Thanks. πŸ˜„
                                  • novenaN Offline
                                    novena
                                    neat and clean renders, nicely done Massimo...
                                    http://hdzarkitektur.wordpress.com/
                                    • massimoM Offline
                                      massimo Moderator
                                      Thanks Victor. πŸ˜„
                                      • marked001M Offline
                                        marked001
                                        I somehow missed these.. these are beautiful and really impressive with all of that white.
                                        I have not ventured past the Interior Medium setting.. I'd be interested to see quality differences across the settings.
                                        http://www.revision21vis.com
                                        instagram: revi21on
                                        • olisheaO Offline
                                          olishea
                                          Yes massimo, the specular to the ceramic it looks great. What does it look like?
                                          oli
                                          • GubermenschG Offline
                                            Gubermensch
                                            Incredible! Any chance you'd share the mirror mat.pack? πŸ˜„
                                            http://www.jacobgubler.com/
