    How to hide the maximize & minimize web-dialog button?
    12 Posts 5 Posters 1.4k Views 5 Watching
    • renderizaR
      renderiza
      I opened the extension warehouse web-dialog in SketchUp and I noticed it only showed the close button at the top right corner of the web-dialog...How can I not show maximize & minimize buttons?
      Thanks in advance!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • Dan RathbunD
        Dan Rathbun
        Try setting the webdialog to a fixed size (min == max, in both x & y), with the sizable argument to false.
        I'm not here much anymore.
        • renderizaR
          renderiza
          Hi, thanks for respond...bellow is what I tried but the max & min button are still showing. πŸ˜•
          dialog = UI;;WebDialog.new("Test", false, "Test", 420, 500, 400, 400, false)
          dialog.set_size(420, 500)
          dialog.max_width = 420
          dialog.min_width = 420
          dialog.max_height = 500
          dialog.min_height = 500
          dialog.set_file(file)
          dialog.show()
          • TIGT
            The EW is NOT a 'normal' webdialog.
            Our paltry webdialogs will show the PC top-bar 3 buttons [although on MAC I think you can hide them ?]
            As Dan says - setting the webdialog's height's max and min to the same pixel values and then the same for the width's max and min, will then make it a fixed size - so the user can NOT drag out its edges to resize it. The top-bar 3 buttons will always display: when clicked they will still close it, minimize it etc...
            • renderizaR
              renderiza
              Maybe in the future this will be allowed...Thanks for reply! πŸ‘
              • jiminy-billy-bobJ
                jiminy-billy-bob
                You can make your webdialog a toolwindow, though : http://sketchucation.com/forums/viewtopic.php?p=280331#p280331
                • renderizaR
                  renderiza
                  This might be the answer for making better looking web-dialogs!...Thanks! πŸ‘
                  • Dan RathbunD
                    Dan Rathbun
                    But it only applies on PC.
                    • tt_suT
                      tt_su
                      Indeed, I never found a way to do the same for OSX. 😞
                      • TIGT
                        You could perhaps make an 'ordinary' very small webdialog located 'off-screen' [-ve XY ?].
                        Then run all of the tool's input/output through a js generated 'popup window' - which you can then style to suit your wishes using some clever js and css ?
                        Urm... how to get it to appear mid-screen when the parent is off-screen [just some convoluted math ?] ??
                        Just idle musings, not tested at all... πŸ˜’
                        • jiminy-billy-bobJ
                          jiminy-billy-bob
                          Did anyone find a way to collapse these (fake-)toolwindows by clicking on its title bar ?
                          • tt_suT
                            tt_su
                            Didn't try. Then you'd have to hook into the windows messages. yuck
