πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
How to hide the maximize & minimize web-dialog button?
12 Posts 5 Posters 896 Views 5 Watching
    renderiza
    I opened the extension warehouse web-dialog in SketchUp and I noticed it only showed the close button at the top right corner of the web-dialog...How can I not show maximize & minimize buttons?
    Thanks in advance!
    [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      Dan Rathbun
      Try setting the webdialog to a fixed size (min == max, in both x & y), with the sizable argument to false.
      I'm not here much anymore.
        renderiza
        Hi, thanks for respond...bellow is what I tried but the max & min button are still showing. πŸ˜•
        dialog = UI;;WebDialog.new("Test", false, "Test", 420, 500, 400, 400, false)
        dialog.set_size(420, 500)
        dialog.max_width = 420
        dialog.min_width = 420
        dialog.max_height = 500
        dialog.min_height = 500
        dialog.set_file(file)
        dialog.show()
          The EW is NOT a 'normal' webdialog.
          Our paltry webdialogs will show the PC top-bar 3 buttons [although on MAC I think you can hide them ?]
          As Dan says - setting the webdialog's height's max and min to the same pixel values and then the same for the width's max and min, will then make it a fixed size - so the user can NOT drag out its edges to resize it. The top-bar 3 buttons will always display: when clicked they will still close it, minimize it etc...
            renderiza
            Maybe in the future this will be allowed...Thanks for reply! πŸ‘
              jiminy-billy-bob
              You can make your webdialog a toolwindow, though : http://sketchucation.com/forums/viewtopic.php?p=280331#p280331
                renderiza
                This might be the answer for making better looking web-dialogs!...Thanks! πŸ‘
                  Dan Rathbun
                  But it only applies on PC.
                    tt_su
                    Indeed, I never found a way to do the same for OSX. 😞
                      You could perhaps make an 'ordinary' very small webdialog located 'off-screen' [-ve XY ?].
                      Then run all of the tool's input/output through a js generated 'popup window' - which you can then style to suit your wishes using some clever js and css ?
                      Urm... how to get it to appear mid-screen when the parent is off-screen [just some convoluted math ?] ??
                      Just idle musings, not tested at all... πŸ˜’
                        jiminy-billy-bob
                        Did anyone find a way to collapse these (fake-)toolwindows by clicking on its title bar ?
                          tt_su
                          Didn't try. Then you'd have to hook into the windows messages. yuck
