    Problem with removing letters from string
    10 Posts 5 Posters 747 Views 5 Watching
    • renderizaR Offline
      renderiza
      How can I remove the first four letters of a string?
      Here is a test that is giving me strange result...
      a = "hello there"
      a[1] #=> "101"
      I was expecting this...
      a = "hello there"
      a[1] #=> "e"
      What I am doing wrong?
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        renderiza
        This one seems to work.
        a = "hello there"
        a[1,1] #=> "e"
          slbaumgartner
          a = "hello there"
          a[1] #=> "101"
          a = "hello there"
          a[1] #=> "e"
          a[1] returns the character in the second position of the string, and in the version of Ruby embedded in SketchUp a character is displayed as its numeric value, not its ASCII representation. You can use a[1].chr to get a string containing the ASCII.
          In your second example, a[1,1] is a length 1 slice from the string, which is also a string (not a character) so it displays as a string.
          • Dan RathbunD Offline
            Dan Rathbun
            Be careful, ... in Ruby 1.9+ they changed the [ ] method to return what we all expect an index to return.
            try using a range:
            a = "hello there" b = a[4..-1] %(#804000)[>> "o there"]
            I'm not here much anymore.
              renderiza
              thank you guys!
              Here is what I ended up using to eliminate first four letters...
              "sting"[4,100] #=> "g"
              • tt_suT Offline
                tt_su
                I would recommend you use Dan suggestions as it's always correct. You example will fail when you feed it a string that's over 100 characters. And it's not a good practice to give out of range values.
                  renderiza
                  Will replace the code to Dan is suggestion for the next update of "Rename by Layer" plugin.
                  Thanks! 👍
                    BUT be aware that non-ASCII accented characters etc are actually 'two-bits'...
                    So then
                    **a = "héllo there"** héllo there **b = a[4..-1]** lo there
                    BUT all is not lost:
                    **a = "hello there" b = a.split('')** ["h", "e", "l", "l", "o", " ", "t", "h", "e", "r", "e"]
                    AND
                    **a = "héllo there" b = a.split('')** ["h", "é", "l", "l", "o", " ", "t", "h", "e", "r", "e"]
                    SO THEN
                    **b = a.split('')[4..-1].join('')** o there
                    should do it, even with strings containing non-ASCII characters 💭
                    • tt_suT Offline
                      tt_su
                      Interesting - split uses regex functions, which is to an extent in Ruby 1.8 aware of Unicode.
                        renderiza
                        @tig said:
                        SO THEN
                        Great advice!...thank you guys! 👍
