    Save Section Plane..."Reverse" by Scene
    5 Posts 2 Posters 435 Views 2 Watching
      Charlie__V
      All,
      I know SU will not save the Section Plane "Reverse" attribute on a scene by scene basis.
      So my question is.....does anyone (else) see this as a useful "option".
      IOW....if you have a Section Plane...say with a view oriented North....and desire a same position & view facing South (180°).....why not use the same Section Plane....invoke the reverse option....and simply create a scene using the same Section Plane.
      Currently I use 2 seperate Section Planes...(1 North & 1 South/per above example)...offset a small amount usually ~ 3" or so.
      Charlie
      • Wo3DanW Offline
        Wo3Dan
        ...I know SU will not save the Section Plane "Reverse" attribute on a scene by scene basis.
        Yes, +1. For not saving the "direction" of section plane seems like a missed opportunity. Something they missed when deciding what to save per scene.
        Setting up animations is going to be slightly different!
        Anyway, +1
          Charlie__V
          Anyway, +1
          Gerit,
          Thanks for your reply...I guess there is not much interest or need for above stated.
          I selfishly wished for it.......given currrent modeling requirement.
          IE: Imagine the need to document (2d) building interior (X-sections) elevation(s)and have the option to use the same X-Section Plane..........Twice(2x).......From same camera position...albeit 180°.
          Again........if not great demand for such........no real big deal...it would of course greatly simplify above mentioned scenario.
          Again, thanks for your reply..........BTW....not sure I follow the "Setting up animations is going to be slightly different"??
          Charlie
          • Wo3DanW Offline
            Wo3Dan
            As it is now:
            Scene A with section plane 1 active
            Scene B with section plane 2 active, different location though.
            The animation from A to B (and back) shows the transition of the section cut running from A to B (and back) (scene transitions enabled and unequal to zero)
            With your suggestion:
            Scene B with section plane 1 still active, different location though.
            The only minor difference is that things are much simpler now without the need of an extra section plane.
              Charlie__V
              Scene B with section plane 1 still active, different location though..
              Thanks Gerrit,
              To split hairs.....I envision section plane 1 uses same position (location) for "Scenes A&B"...only camera "B" is 180° to Camera "A".(think turntable)
              I envision a "sweeping" 180° Turn/transition from "A" to "B" using the same plane.......yes...unlike the current transition from one plane to another....though maybe the sweeping transition would be more........??...sexy?
              Again...thanks for you input/thought's.
              Best,
              Charlie
