    HUGE problem with section slice groups !!!
    6 Posts 4 Posters 623 Views 4 Watching
    • H Offline
      hygicell
      finalising my project after 100ds of hours of work,
      I wanted to include some section cuts
      sections worked fine, create group from slice also
      moving this group to where I could work on it: fine again
      when I wanted to slightly adapt the sliced group (add some lines to form new surfaces, paint some surfaces a different color, etc...)
      I noticed there are groups within the sliced group which made it impossible to do what I wanted
      so I proceeded to explode the groups within the sliced group one after the other
      got what I wanted (at least I thought so), so I saved my project this morning under it's original name, erasing the previous version
      upon reopening it, I notice that all original groups and components are exploded, not only within, as I wanted, but also outside the sliced group
      so now everything sticks together, and I have no backup
      this is dramatic: it will take me hours to repair
      please help
      Frank
      • K Offline
        kaas
        If you save the file using the old name like <name.skp> at the same time Sketchup makes a backup file <name.skb> file. That skb file should contain the previous saved skp-file.
        So rename the <name.skb> to something like <old.skp> and open that file. If you're lucky, all you components will be like before.
        I hope it works out for you!
        edit: search in the forum for the archiver ruby plugin. I use it all the time and it really is a life saver in situations like this.
        • H Offline
          hygicell
          thanks, Kaas,
          but if you save your project under the same name, I imagine the .skb file is also updated
          this is what I did, as I had no reason to suspect that anything was wrong:
          who would think that exploding an image of a group or component in a section slice will also explode the original group and component ?
          thanks for the tip concerning the archive plugin
          I already had it installed,
          but it has improved a lot, so I upgraded
          a timer would be ideal for automatic archiving
          I probably wouldn't have used it, as I was confident nothing wass amiss
          to my opinion this is a huge bug in Sketchup
          Frank
          • K Offline
            kaas
            Did you actually check the skb? If you have saved the 'wrong file' multiple times the skb won't be of any help indeed.
            I just tested this by making a group and a component and creating a group from slice. In the group with the section SketchUp creates are unique components, one for every group and component you're slicing (I checked with the outliner). I can't see any bug there so I'm not sure what happened in your file.
              sonder
              I wish I could help you, but if you don't have a previously saved version, you may be out of luck and need to regroup the things you exploded.
              This is actually another good reason to keep a master SU model on a given project and reference it into separate files for things like sections, RCP, Interiors...etc.
              • P Offline
                pcmoor
                I did something similar,how about using the windows back-up files, save what you have to a thumb drive or disc, then return the documents to a previous saved backup
