    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] Rename by Layer v1.0.3
    51 Posts 18 Posters 24.2k Views 18 Watching
      rv1974
      the window could be 80% smaller πŸ˜•
      • renderizaR Offline
        renderiza
        You can make the content smaller by pressing ( ctrl - ). What is the resolution of your screen...can I see screen capture?
        In the future maybe collapsible tabs may help but not sure.
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          dedmin
          It is getting really great - BIG THANKS!!
          Can We have an option to append the layer name or/and numbers to the existing component's/group's names?
            renderiza
            That is good suggestion so lets see if it can be added to next update. πŸ‘
            • cmeedC Offline
              cmeed
              Amazing! Really Really good. A great companion to this is "Layers Panel" - photoshop layers window with nested layers. still in Beta and some wrinkles to iron out but, Like this plugin, very impressive!!
              All i could say on a negative - could we have a smaller window? it takes up alot of space and we know the name of it, if we lost the logo (sorry), at least i'd get back half my screen. πŸ˜†
              cheers for the great plugin
              c
              • cmeedC Offline
                cmeed
                I never knew this!!! Duh!
                c
                  renderiza
                  I am a big fan of "Layers Panel" and think everyone should have it...Can't recommend it enough! http://sketchucation.com/forums/viewtopic.php?p=488833#p488833
                  Next update should have smaller windows and I agree that the logo is taking too much space.
                  Thanks for feedback...cheers! πŸ‘
                    renderiza
                    [pre:2yc1rtr7]Authors:: | Bagatelo| Renderiza |
                    Plugin Name:: Rename by Layer
                    Version:: 1.0.3
                    Date:: 9/17/2013
                    Cost:: Free[/pre:2yc1rtr7]
                    Rename by Layer v1.0.3 is now available for download.
                    %(#909090)[What is new:
                    • The web-dialog is smaller
                    • Keep existing name - This will include the existing name to the newly created one. For example:
                      Layer = bed
                      Existing name = door
                      Add Number = True / Prefix
                    Result = 001 - bed - door]
                    Again thanks for feedback! πŸ‘
                    Note: Need to recheck "Keep existing name" feature since its not working...will try to fix it as soon. πŸ˜•
                      renderiza
                      Fixed the "keep existing name" feature but in the mean time it should work only on groups.
                      • JQLJ Offline
                        JQL
                        Unbelievable Renderiza, your plugin is now able to rename without changing name? What a paradox... If I didn't see it with my own eyes I wouldn't think it was even possible!
                        Thank you again,
                        JQL
                        www.casca.pt
                        Visit us on facebook!
                        • cmeedC Offline
                          cmeed
                          I have an idea....
                          Its struck me that as I work I'm naming as I go. If i do bulk renaming then i really need all the options of the window, If I'm naming as I go then I don't...
                          to save opening it each time could the last parameter/settings just be stored and a Shortcut key can be assigned. I just press the shortcut and viola .....
                          no need to open the window and change the settings
                          Speed increased
                          5p more earned
                          earlier home by three seconds
                          c
                            renderiza
                            @cmeed said:
                            I have an idea....
                            Speed increased
                            5p more earned
                            c
                            This is really good idea!
                            I first need to become familiar with storing web-dialog parameters/settings with maybe 'HTML5 Web Storage'. After learning how to do that I will try to integrate you suggestion. πŸ‘
                            Thanks!
                            • jiminy-billy-bobJ Offline
                              jiminy-billy-bob
                              http://www.sketchup.com/intl/en/developer/docs/ourdoc/sketchup.php#write_default
                              πŸ˜‰
                                renderiza
                                πŸ˜‰
                                It seems HTML 5 localStorage & sessionStorage can't work locally without having a server installed so that means I can't use that technology. 😒
                                Hopefully I can have more luck with 'Sketchup.write_default'. πŸ˜’
                                Thanks!
                                  me_turcotte
                                  I'm looking for a plugin or a script that would clear the name field of all components and groups. I tried yours, but i need to do it one component at a time. Any idea of how I could clear all of the names at the same time? Even for nested components and groups?
                                  • JQLJ Offline
                                    JQL
                                    You can rename a selection of multiple components with this plugin. I never tried renaming to a clear name though.
                                    www.casca.pt
                                      me_turcotte
                                      Thank you JQL. It works with multiple components and groups at the same level but not with nested components. And I am able to clear the name by hitting the space bar in the "enter text" area.
                                      It would be really useful to clear all the names at one time.
                                        sibenj
                                        Hi, any plans for a 2015/mac cmpatible update?? Wuld love to try this plugin...
                                        • bmikeB Offline
                                          bmike
                                          This is a great plugin... but... I can't get the icon to go away. I am on a Mac Yosemite, SketchUp 2015 and 2016 had the same problem. Install the extension, close the toolbar, restart SketchUp and the tool bar appears again.
                                          Otherwise, wonderful extension.
                                          mike beganyi design + consulting llc
                                            driven
                                            mike
                                            I think you'll need to edit the plugin yourself...
                                            I'll see if I have a copy and what line needs the tweak...
                                            john
                                            • 2 / 3
