    [Plugin] Rename by Layer v1.0.3
    51 Posts 18 Posters 27.5k Views 18 Watching
    • cmeedC Offline
      cmeed
      Amazing! Really Really good. A great companion to this is "Layers Panel" - photoshop layers window with nested layers. still in Beta and some wrinkles to iron out but, Like this plugin, very impressive!!
      All i could say on a negative - could we have a smaller window? it takes up alot of space and we know the name of it, if we lost the logo (sorry), at least i'd get back half my screen. πŸ˜†
      cheers for the great plugin
      c
      • cmeedC Offline
        cmeed
        @renderiza said:
        You can make the content smaller by pressing ( ctrl - ). What is the resolution of your screen...can I see screen capture?
        In the future maybe collapsible tabs may help but not sure.
        I never knew this!!! Duh!
        c
        • renderizaR Offline
          renderiza
          I am a big fan of "Layers Panel" and think everyone should have it...Can't recommend it enough! http://sketchucation.com/forums/viewtopic.php?p=488833#p488833
          Next update should have smaller windows and I agree that the logo is taking too much space.
          Thanks for feedback...cheers! πŸ‘
          [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
            renderiza
            [pre:2yc1rtr7]Authors:: | Bagatelo| Renderiza |
            Plugin Name:: Rename by Layer
            Version:: 1.0.3
            Date:: 9/17/2013
            Cost:: Free[/pre:2yc1rtr7]
            Rename by Layer v1.0.3 is now available for download.
            %(#909090)[What is new:
            • The web-dialog is smaller
            • Keep existing name - This will include the existing name to the newly created one. For example:
              Layer = bed
              Existing name = door
              Add Number = True / Prefix
            Result = 001 - bed - door]
            Again thanks for feedback! πŸ‘
            Note: Need to recheck "Keep existing name" feature since its not working...will try to fix it as soon. πŸ˜•
              renderiza
              Fixed the "keep existing name" feature but in the mean time it should work only on groups.
              • JQLJ Offline
                JQL
                Unbelievable Renderiza, your plugin is now able to rename without changing name? What a paradox... If I didn't see it with my own eyes I wouldn't think it was even possible!
                Thank you again,
                JQL
                www.casca.pt
                Visit us on facebook!
                • cmeedC Offline
                  cmeed
                  I have an idea....
                  Its struck me that as I work I'm naming as I go. If i do bulk renaming then i really need all the options of the window, If I'm naming as I go then I don't...
                  to save opening it each time could the last parameter/settings just be stored and a Shortcut key can be assigned. I just press the shortcut and viola .....
                  no need to open the window and change the settings
                  Speed increased
                  5p more earned
                  earlier home by three seconds
                  c
                    renderiza
                    @cmeed said:
                    I have an idea....
                    Speed increased
                    5p more earned
                    c
                    This is really good idea!
                    I first need to become familiar with storing web-dialog parameters/settings with maybe 'HTML5 Web Storage'. After learning how to do that I will try to integrate you suggestion. πŸ‘
                    • jiminy-billy-bobJ Offline
                      jiminy-billy-bob
                      http://www.sketchup.com/intl/en/developer/docs/ourdoc/sketchup.php#write_default
                      πŸ˜‰
                        renderiza
                        πŸ˜‰
                        It seems HTML 5 localStorage & sessionStorage can't work locally without having a server installed so that means I can't use that technology. 😒
                        Hopefully I can have more luck with 'Sketchup.write_default'. πŸ˜’
                          me_turcotte
                          I'm looking for a plugin or a script that would clear the name field of all components and groups. I tried yours, but i need to do it one component at a time. Any idea of how I could clear all of the names at the same time? Even for nested components and groups?
                          • JQLJ Offline
                            JQL
                            You can rename a selection of multiple components with this plugin. I never tried renaming to a clear name though.
                            www.casca.pt
                              me_turcotte
                              Thank you JQL. It works with multiple components and groups at the same level but not with nested components. And I am able to clear the name by hitting the space bar in the "enter text" area.
                              It would be really useful to clear all the names at one time.
                                sibenj
                                Hi, any plans for a 2015/mac cmpatible update?? Wuld love to try this plugin...
                                • bmikeB Offline
                                  bmike
                                  This is a great plugin... but... I can't get the icon to go away. I am on a Mac Yosemite, SketchUp 2015 and 2016 had the same problem. Install the extension, close the toolbar, restart SketchUp and the tool bar appears again.
                                  Otherwise, wonderful extension.
                                    driven
                                    mike
                                    I think you'll need to edit the plugin yourself...
                                    I'll see if I have a copy and what line needs the tweak...
                                    • bmikeB Offline
                                      bmike
                                      @driven said:
                                      mike
                                      Thanks John. I have done that with most plugins... once someone points me to the code or the line...
                                      But I'm not at all capable or writing Ruby... so I thought I'd ask.
                                      -Mike
                                        driven
                                        without testing...
                                        in the menu ruby, you need to change line 63 rnd_renamer_tb.show
                                        		rnd_renamer_tb.restore
                                        it should then honour last state...
                                        • bmikeB Offline
                                          bmike
                                          @driven said:
                                          without testing...
                                          that worked. thanks....
                                          also figured out how to change the HTML window size, always bugged me that the content didn't show in the window and i'd have to stretch it to see what i was doing.
                                            retep37
                                            Does anyone know if Rename by Layer v1.0.3 works in SketchUp 2015 or SketchUp 2016? I am not familiar with the tool, but tried it in SketchUp 2015 (on Windows) today and although it loaded I could not get it to do anything. Above, somone mentioned SU 2015, but I think on Mac, not sure if the OS would matter.
                                            PeterB
                                            • 2 / 3
