    [Plugin] Rename by Layer v1.0.3
    51 Posts 18 Posters 26.2k Views 18 Watching
    • JQLJ Offline
      JQL
      Are you real Renderiza?
      Are you peeking on my shoulder and coding while I'm writing? Are you doing it right now? Yikes!
      Let me test and I will answer!
      Thanks,
      JQL
      www.casca.pt
      Visit us on facebook!
      • JQLJ Offline
        JQL
        Ghosteriza you uncanny coder,
        I already tested it and you nailed it! The option to write a name is awesome!
        The only option the plugin lacks right now could be "renaming selection only". If you manage to pull it off too, then it covers everything I need for now and in the predictable future... in terms of renaming!
        There is still some room for improvement... If you are the prefectionist it seems you are, you could some how automate/facilitate the process described in the images that follow.
        The idea for plugin that I was talking about before was to rename groups/components, using the name of the group/components where they are nested in. When you are working inside a group called "columns" every group component inside it would be renamed to "columns - 00n" whatever the layer they would be on.
        In other words your dialog would have a logo that would say "My name is: rename by GROUP". For me it's redundant now, but I can see some uses though. Maybe create even one more option would solve it.
        This would pose a new problem though... your plugin would be much more than layer based naming, and you could also want to change the name of the plugin. You have a keen sense for names/renames so I bet you can figure out something funny! An image that crosses my mind would be Swiss Army Kname... πŸ˜•
        Thanks and thanks, and get the hell out of my shoulder... It spooks me!
        JQL
        This is what happens when the names are cleared. Groups are sketchup standard, components get no name... perfect!
        When renaming without numbering instances all have the same name and definitions aquire sketchup standards. Perfect! If one adds numbering, components and groups will create double names... Definition names will get a bit confusing... not so perfect but excellent nonetheless!
        I imagine it isn't easy to automate this processes. However if one could somehow choose to rename/clear only instances names or definition names the job would be handled much easily. The options would get denser and the plugin would probably become a bit confusing... but very powerful.
        www.casca.pt
        • JQLJ Offline
          JQL
          What a powerful concept! Could make me rethink the way I manage my Sketchup models...
          Could the plugin be adapted to also have a filter for the active layer?
          Thank you very much!
          www.casca.pt
          • renderizaR Offline
            renderiza
            Will try to add this feature for next update.
            Good idea indeed will see if I can work on it. πŸ‘
            Love it! 🀣 πŸ‘
            Will see how that can be a feature for next update.
            Note: By the way thanks for making me laugh! 🀣 πŸ‘
            [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
              renderiza
              [pre:m1n0fdbx]Authors:: | Bagatelo| Renderiza |
              Plugin Name:: Rename by Layer
              Version:: 1.0.2
              Date:: 9/14/2013
              Cost:: Free[/pre:m1n0fdbx]
              Rename by Layer v1.0.2 is now available for download.
              %(#909090)[Thanks to the people that contributed ideas to make the plugin better! πŸ‘]
              • bagateloB Offline
                bagatelo
                Very good updates. It's almost unbelievable that something like this is not already done before.
                • KrisidiousK Online
                  Krisidious
                  great idea... really great for organizing models.
                  By: Kristoff Rand
                    rv1974
                    the window could be 80% smaller πŸ˜•
                      renderiza
                      You can make the content smaller by pressing ( ctrl - ). What is the resolution of your screen...can I see screen capture?
                      In the future maybe collapsible tabs may help but not sure.
                        dedmin
                        It is getting really great - BIG THANKS!!
                        Can We have an option to append the layer name or/and numbers to the existing component's/group's names?
                          renderiza
                          That is good suggestion so lets see if it can be added to next update. πŸ‘
                          • cmeedC Offline
                            cmeed
                            Amazing! Really Really good. A great companion to this is "Layers Panel" - photoshop layers window with nested layers. still in Beta and some wrinkles to iron out but, Like this plugin, very impressive!!
                            All i could say on a negative - could we have a smaller window? it takes up alot of space and we know the name of it, if we lost the logo (sorry), at least i'd get back half my screen. πŸ˜†
                            cheers for the great plugin
                            c
                            • cmeedC Offline
                              cmeed
                              I never knew this!!! Duh!
                              c
                                renderiza
                                I am a big fan of "Layers Panel" and think everyone should have it...Can't recommend it enough! http://sketchucation.com/forums/viewtopic.php?p=488833#p488833
                                Next update should have smaller windows and I agree that the logo is taking too much space.
                                Thanks for feedback...cheers! πŸ‘
                                  renderiza
                                  [pre:2yc1rtr7]Authors:: | Bagatelo| Renderiza |
                                  Version:: 1.0.3
                                  Date:: 9/17/2013
                                  Cost:: Free[/pre:2yc1rtr7]
                                  Rename by Layer v1.0.3 is now available for download.
                                  %(#909090)[What is new:
                                  • The web-dialog is smaller
                                  • Keep existing name - This will include the existing name to the newly created one. For example:
                                    Layer = bed
                                    Existing name = door
                                    Add Number = True / Prefix
                                  Result = 001 - bed - door]
                                  Again thanks for feedback! πŸ‘
                                  Note: Need to recheck "Keep existing name" feature since its not working...will try to fix it as soon. πŸ˜•
                                    renderiza
                                    Fixed the "keep existing name" feature but in the mean time it should work only on groups.
                                    • JQLJ Offline
                                      JQL
                                      Unbelievable Renderiza, your plugin is now able to rename without changing name? What a paradox... If I didn't see it with my own eyes I wouldn't think it was even possible!
                                      Thank you again,
                                      JQL
                                      www.casca.pt
                                      • cmeedC Offline
                                        cmeed
                                        I have an idea....
                                        Its struck me that as I work I'm naming as I go. If i do bulk renaming then i really need all the options of the window, If I'm naming as I go then I don't...
                                        to save opening it each time could the last parameter/settings just be stored and a Shortcut key can be assigned. I just press the shortcut and viola .....
                                        no need to open the window and change the settings
                                        Speed increased
                                        5p more earned
                                        earlier home by three seconds
                                        c
                                          renderiza
                                          @cmeed said:
                                          I have an idea....
                                          Speed increased
                                          5p more earned
                                          c
                                          This is really good idea!
                                          I first need to become familiar with storing web-dialog parameters/settings with maybe 'HTML5 Web Storage'. After learning how to do that I will try to integrate you suggestion. πŸ‘
                                          • jiminy-billy-bobJ Offline
                                            jiminy-billy-bob
                                            http://www.sketchup.com/intl/en/developer/docs/ourdoc/sketchup.php#write_default
                                            πŸ˜‰
                                            • 2 / 3
