    Curved Staircases
    171 Posts 19 Posters 54.1k Views 19 Watching
      driven
      @Walt
      what do you get if you paste this in 'Ruby Console'
       status = Sketchup.is_online
      @Garry I PM'd them the other day?
      john
        mwm5053
        @Driven
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
        • jeff hammondJ Offline
          jeff hammond
          @garry k said:
          Jeff have you tried with template of feet?
          yeah.. and i encountered another error with it (using the 2013 template Engineering - Feet
          i keeping getting the error 'Tread bullnose must be at least 1/2 of tread thickness'.
          the settings i'm using while getting that error are:
          Tread Thickness: 0.125' (or 1.5")
          Tread Bullnose: 0.083' (or 1")
          so the error message isn't corresponding to my settings (if i'm properly understanding the message and settings)
          My plan is to connect to web while in trial. Once a user is licensed then connecting to web site will no longer be necessary.
          oh.. i see. that sounds good
          dotdotdot
          • G Offline
            Garry K
            Jeff - both the top and bottom of the tread get bullnosed. So you can't bullnose the top with a 1" radius and the bottom with a 1" radius.
            In this case the maximum bullnose for a 1.5" tread is 0.75".
            • G Offline
              Garry K
              Walt - all I can think of doing is pulling out the http code and putting it into a very simple rb script ( not scrambled ).
              What user ID are you using? If it isn't the default "User" "test" then I will see what my logs show at the web site. We'll see if we made it that far.
              • G Offline
                Garry K
                John - I looked at my PM messages - I have only received 1 since I put up version 1.0.7 08 Feb 2014, 08:39( which had the feet fix ).
                Your last message had to do with the beta version 2014.
                  mwm5053
                  @ Garry username is mwm5053. I have been able to Login to website with no problems still getting 101 error after clicking ok web dialogue pops up but clicking ok for default values nothing happens heres a screenshot.
                  2011 iMac
                  V2 Twilight
                  • G Offline
                    Garry K
                    Walt - If you look at the title of the web dialog it is saying "http error 0". Sorry about the confusion. I thought that it would be good to show the web dialog whether you have an error or not? I could change the back ground color from wheat to red or something like that.
                    The other thing to note is that you may need more accuracy than 1/2" precision to properly draw a stair case. I'm not exactly sure how sketchup handles smaller values than precision.
                    If you let the defaults.txt file to "User" and "test" and connected then you should see "Testing - temporary status granted"
                    If you edited defaults.txt file to "mwm5053" and put in the emailed password then you should see "You have 30 days left in trial"
                      mwm5053
                      I changed defaults txt back to user / test and precision to 1/64 still get screenshot error
                      2011 iMac
                      V2 Twilight
                      • G Offline
                        Garry K
                        Walt - I went to my web site and took a look. There isn't a single http attempt for user "mwm5053".
                        I also looked at all of my registered users and there isn't a user "mwm5053" in that file.
                        You need to go to my web site - CabMaker32.com and click logon and register. You will then receive an email with your password. You can also send me a private message with your email address. I can also look in my user file and see if that email address has been registered under perhaps a different user.
                          mwm5053
                          Now thats really weird
                          2011 iMac
                          V2 Twilight
                            jeff hammond
                            that's what i thought.. you may want to consider changing the wording of the error message then:
                            to something along the lines of:
                            max bullnose is 1/2 tread thickness.
                            dotdotdot
                              driven
                              @Garry
                              it's working in 'feet' Template now...
                              the cache reset took a couple of goes...
                              added some info so you can see what I get my end...
                              Ruby version is _____________ 1.8.5 Sketchup version is __________ 13.0.4811 Sketchup version path is __________ /Applications/SketchUp 2013/SketchUp.app Sketchup process pid is __________ 86823 @modPath is __________ unsaved stair time 0.922734 stair time 0.922350
                              <html><head>
                              <meta http-equiv="MSThemeCompatible" content="Yes">
                              <style type="text/css">
                                * { padding; 0; margin; 0; }
                                body { background-color; #F9EBD1}
                                fieldset { float; left; background-color; #F9EBD1; border-color; black; margin; 3px;}
                                fieldset p {display; table-row;
                              			  font-family; Arial, Helvetica, sans-serif;
                              			  font-size; 90%; color; black; height; 27px;}
                                fieldset input,
                                fieldset select,
                                fieldset label {display; table-cell; margin; 2px; width; 120px;}
                                fieldset label {text-align; right;}
                                fieldset input,
                                fieldset select {margin-left; 10px; background-color; wheat;}
                              </style>
                              </head>
                              <body>
                              <form>
                                  <fieldset>
                                      <p><label>Inside Stringer;</label><select id="inside_stringer"><option>Housed</option><option>Sawtooth</option><option>None</option></select></p>
                                      <p><label>Options;</label><select id="inside_option"><option>Has Heel</option><option>Has Foot</option><option>Both</option><option>None</option></select></p>
                                      <p><label>Thickness;</label><input type="text" id="inside_thickness"></p>
                                      <p><label>Width;</label><input type="text" id="inside_width"></p>
                                      <p><label>Rail Options;</label><select id="inside_rail"><option>Guard Rail</option><option>Wall Rail</option><option>None</option></select></p>
                                  </fieldset>
                                  <fieldset>
                                      <p><label title="Set to none for a spiral where spindles are used to tie the treads togethers">Outside
                                          Stringer;</label><select id="outside_stringer"><option>Housed</option><option>Sawtooth</option><option>None</option></select></p>
                                      <p><label>Options;</label><select id="outside_option"><option>Has Heel</option><option>Has Foot</option><option>Both</option><option>None</option></select></p>
                                      <p><label>Thickness;</label><input type="text" id="outside_thickness"></p>
                                      <p><label>Width;</label><input type="text" id="outside_width"></p>
                                      <p><label>Rail Options;</label><select id="outside_rail"><option>Guard Rail</option><option>Wall Rail</option><option>None</option></select></p>
                                  </fieldset>
                                  <fieldset>
                                      <p><label>Stair Direction;</label><select id="direction"><option>Clockwise</option><option>Anti Clockwise</option></select></p>
                                      <p><label>Stair Width;</label><input type="text" id="stair_width"></p>
                                      <p><label title="Set to 0 and StairMaker will calculate based on degrees and Average Run">Radius;</label><input type="text" id="radius"></p>
                                      <p><label title="Set to 0 and StairMaker will calculate based on radius and Average Run">Degrees;</label><input type="text" id="degrees"></p>
                                      <p><label>Rail Style;</label><select id="rail_style"><option>Classic</option><option>Modern</option><option>Round</option><option>Square</option><option>Standard</option><option>Traditional</option></select></p>
                                      <p><label>Open Risers;</label><input type="checkbox" id="open_riser"></p>
                                      <p><label>Total Rise;</label><input type="text" id="total_rise"></p>
                                      <p><label>Risers;</label><input type="text" id="risers"></p>
                                      <p><label>Riser Thickness;</label><input type="text" id="riser_thickness"></p>
                                  </fieldset>
                                  <fieldset>
                                      <p><label>Tread Thickness;</label><input type="text" id="tread_thickness"></p>
                                      <p><label title="Average Run is ignored if both Radius and Degrees are set">Average Run;</label><input type="text" id="average_run"></p>
                                      <p><label>Tread Bullnose;</label><input type="text" id="tread_bullnose"></p>
                                      <p><label>Nosing;</label><input type="text" id="nosing"></p>
                                      <p><label>Flare Amount;</label><input type="text" id="flare_amount"></p>
                              		<p><label>Progressive Flare;</label><input type="text" id="progressive_flare"></p>
                                      <p><label>Flare Count;</label><input type="text" id="flare_count"></p>
                                      <p><label>Floor Thickness;</label><input type="text" id="floor_thickness"></p>
                                      <p><label>Create Stair;</label><input type="button" onclick="do_click()" style="background; silver" value="OK"></p>
                                  </fieldset>
                              </form>
                              <script type="text/javascript">
                              if ( document.addEventListener )
                              	document.addEventListener( "DOMContentLoaded", ready, false );
                              else if ( document.attachEvent )
                              	document.attachEvent( "onreadystatechange", check_ready );
                              function do_click()
                                 var items  = document.getElementsByTagName( '*' );
                                 var count  = items.length;
                                 var text   = "";
                                 for ( var i = 0; i < count; i++ )
                              	  if ( items[i].type == "select-one" )
                              		 value = items[i].options[items[i].selectedIndex].value;
                              	  else if ( items[i].type == "text" )
                              		 value = items[i].value.replace(/'/g, '`');
                              	  else if ( items[i].type == "checkbox" )
                              		 value = items[i].checked.toString();
                              	  else
                              		 value = "";
                              	  if ( value.length > 0 )
                              		  if ( text.length > 0 )
                              			 text += "&";
                              		  text += ( items[i].id + "=" + value );
                                 ruby_call( text );
                              function from_ruby( data )
                              	var element;
                              	var pair;
                              	var pairs = data.split( '&' );
                              	var count = pairs.length;
                              		pair = pairs[i].split( '=' );
                              		element = document.getElementById( pair[0] );
                              		if ( element.type == "select-one" )
                              			if ( pair[1].indexOf('|') == -1 )
                              				element.selectedIndex = pair[1];
                              			else
                              				populate_drop_down( element, pair[1] );
                              		else if ( element.type == "text" )
                              			element.value = pair[1].replace(/`/g, "'");
                              		else if ( element.type == "checkbox" )
                              			element.checked = pair[1] == '1';
                              function populate_drop_down( element, data )
                              	var options = data.split( '|' );
                              	var count   = options.length;
                              	var option;
                              	element.innerText = "";
                              		option = document.createElement( "option" );
                              		option.text = options[i];
                              		element.add( option, null );
                              function ruby_call( text )
                                 query = 'skp;ruby_callback@' + text;
                                 window.location.href = query;
                              function check_ready()
                              	if ( document.readyState === "complete" )
                              		ready();
                              function ready()
                                 ruby_call( 'loaded' );
                              </script>
                              </body></html>
                              • G Offline
                                Garry K
                                Jeff - Good catch. You are correct - the message is worded wrong. I have changed it for the next version.
                                • G Offline
                                  Garry K
                                  Walt - that is wierd - you normally don't see that screen. The web hosting site has been experiencing hack attacks. Please tell me if you see this screen again.
                                  • G Offline
                                    Garry K
                                    Walt - put this rb into your plugins folder and see what you get.
                                    There will be a menu item under plugins called "Web Dialog Test"
                                    test file
                                      mwm5053
                                      Here's my results.
                                      I wonder what the deal is about my login on your site?
                                      2011 iMac
                                      V2 Twilight
                                      • G Offline
                                        Garry K
                                        Walt - I'm sorry but I can't answer that question. I haven't heard anyone else having that problem. It may have something to do with http configurations on your specific machine.
                                        Maybe someone else can answer it. Perhaps start a new thread on this. Maybe the developer forum will catch some attention.
                                        As you can see - the code isn't doing a whole lot.
                                          mwm5053
                                          @ Garry you're right I installed 1.0.8 rbz on Mac Book Pro and works great with no hitches. Mac Pro (desktop) running SU 8 and Lion and Mac Book Pro (laptop) running SU 8 and Mavericks. 😉
                                          2011 iMac
                                          V2 Twilight
                                          • G Offline
                                            Garry K
                                            I now have language translation working. There is a folder called translations and currently there are 4 files in it.
                                            en.lang - English
                                            fr.lang - French
                                            ru.lang - Russian
                                            zh.lang - Chineses ( traditional )
                                            Near the top of the defaults.txt file there is a language= section where you can enter the 2 character language code. If you leave the language= blank the system will try to figure out the locale code.
                                            These language files are straight translations and as a result there might be some funny and or inappropriate translations.
                                            Anyone interested in helping out with any language translation can get a hold of me.
                                            French Stair Maker
                                            Russian Stair Maker
                                            Chinese Stair Maker
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 8 / 9
