    [req]rename objects with name of the layer
    16 Posts 3 Posters 6.9k Views 3 Watching
    • bagateloB Offline
      bagatelo
      It would be possible to create a plugin that renames all groups and components that are within a layer using the name of the layer itself?
      If some layer is named "door", and the objects have different names, after running the script we have names like this:
      "door - 001"
      "door - 002"
      "door - 003"
      "door - 004"
      "door - 005"
      etc ...
      It would be necessary only for objects that were at the root of the outliner.
      If not, someone could create a script or plugin to do this, please?
      I also need a plugin that transforms all groups in components, only those who are at the root of the outliner ...
      Thank you!
      • renderizaR Offline
        renderiza
        Here is little update...
        Both Groups and Components are renamed given the layer they are on now.
        model = Sketchup.active_model
        ents = model.active_entities
        groups = ents.grep(Sketchup;;Group)
        components = ents.grep(Sketchup;;ComponentInstance)
        groups.each do |group|
          group.name = group.layer.name
        components.each do |component|
          component.name = component.layer.name
        Now the part I have not been able to solve is the number side of things. How to make each layer have their own numbers so that they don't conflict with each other like this;
        Don't want:
        door - 001
        door - 002
        door - 003
        window - 004
        window - 005
        Do want;
        door - 001
        door - 002
        door - 003
        window - 001
        window - 002
        Any ideas how to solve this?
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          renderiza
          The code bellow adds the layer name to each group that belong to the layer.
          You mentioned Components as well so will see if I can add that on next example. You also have incrementing numbers to the side so that is another thing to add.
          Note: To test code I recommend using [as] Ruby Code Editor - http://extensions.sketchup.com/en/content/ruby-code-editor but there are other good ones as well.
          Renderiza
            renderiza
            The code below solves the issue mentioned above about the numbers...
            num = 0
              group.name = nil.to_s
              if group.name == nil.to_s
                num=0
              groups.each do |g|
                if group.layer.name == g.layer.name
                  if g.name == nil.to_s
                    num+=1
                    g.name = group.layer.name.concat(" - #{num}")
              component.name = nil.to_s
              if component.name == nil.to_s
                num=0
              components.each do |c|
                if component.layer.name == c.layer.name
                  if c.name == nil.to_s
                    num+=1
                    c.name = component.layer.name.concat(" - #{num}")
            The code uses numbers like this "door - 1" and not like this "door - 001". Do you need it to be like :door - 001" or is it fine like it is?
            • bagateloB Offline
              bagatelo
              Thanks! Thanks! Thanks!
              I like "door - 001"...
              Can you code this to add some option in some menu?
              And I also like to know if we can do it in the whole model or only visible layers....
              Thanks very much!
                renderiza
                Any suggestions for what should be the name of the plugin?
                Below are potential names...
                • Name by Layer
                • Rename by Layer
                • Entities Name by Layer
                • [Re]Name
                • Renamer
                • bagateloB Offline
                  bagatelo
                  [Re] name
                  I think you could create something that rename numerous things, such as materials, components, Layers, etc ...
                  "Central [Re] name"
                  http://sketchucation.com/forums/viewtopic.php?f=323&t=47234
                  http://sketchucation.com/forums/viewtopic.php?f=323&t=53329
                    renderiza
                    @bagatelo said:
                    [Re] name
                    "Central [Re] name"
                    Really like that idea and the name "[Re]Name" is very fitting. But since that idea is more ambitious its advised to work our way there little by little.
                    Maybe starting with renaming groups & components by layer for now and making that into an extension by itself with a different name than "[Re]Name".
                    We can name the extension "Rename by Layer". Here is a Logo for the plugin...Any feedback is welcome.
                    http://s17.postimg.org/m6twx3ekv/Logo_Default.png
                    I started working on making the extension with web-dialog and plan to keep you posted on further progress...cheers!
                    • bagateloB Offline
                      bagatelo
                      Thanks for the work, friend.
                      Very much appreciated.
                      Your logo was very interesting.
                      You could change the code to rename the definition name?
                      The reason I asked this plugin is because I'm trying to use the plugin "Solid Quantify by TAK2HATA". It's a wonderful plugin, and I need something to easily modify the names of components. Note the attachment files.
                      plugs.zip
                      • bagateloB Offline
                        bagatelo
                        Look what I have when I try to execute the last code...
                        Cleared the editor
                        Running the code...
                        Done. Ruby says: Run aborted. Error: undefined method ‘bytesize’ for "1":String
                          dedmin
                          Great plugin! It would be useful to have "append layer name as prefix/suffix" to the component's name.
                            renderiza
                            Great idea! I saw this just about when I published the first version to Plugin Store but maybe for next update your suggestion will be added.
                            Here are some links for the plugin;
                            http://sketchucation.com/resources/pluginstore?pln=RND_Renamer_v1.0.0
                            http://sketchucation.com/forums/viewtopic.php?f=323&t=54165
                            Note: Something important that I noticed about definition names is that if you have 2 entities which are component instances they can't have different definition names.
                            For example;
                            Will not be named like below;
                            Layer: Door
                            component instance#1 definition name = Door - 001
                            component instance#2 definition name = Door - 002
                            component instance#3 definition name = Door - 003
                            component instance#4 definition name = Door - 004
                            They will be name like this;
                            component instance#1 definition name = Door - 004
                            component instance#2 definition name = Door - 004
                            component instance#3 definition name = Door - 004
                            Remember that its a rule that they must be the same. The numbers for definition name will only serve to display the total amount.
                            Cheers! 👍
                              dedmin
                                renderiza
                                Cleared the editor
                                Running the code...
                                This was an error on my part by using bytesize’ method which I will change to 'length' so it will work. Will try to update all the code example above to eliminate that issue.
                                I also published the plugin as an extension on Plugin Store as 'Rename by Layer' here is the link... http://sketchucation.com/resources/pluginstore?pln=RND_Renamer_v1.0.0
                                Also I made another topic here for future updates and stuff... http://sketchucation.com/forums/viewtopic.php?p=490834#p490834
                                Any feedback about the plugin will be great so I know that to fix on next update...Cheers! 👍
                                  renderiza
                                  I will eventually make an extension plugin with web-dialog that offers some options for the user. For now the code bellow displays the numbers like you suggested.
                                  num = 0
                                      num=0
                                    groups.each do |g|
                                          num+=1
                                          bytenum = num.to_s.length
                                          if bytenum  == 1
                                            zeros = "00"
                                          if bytenum  == 2
                                            zeros = "0"
                                          if bytenum  >= 3
                                            zeros = nil.to_s
                                          g.name = group.layer.name.concat(" - #{zeros}#{num}")
                                      num=0
                                          num+=1
                                          if bytenum == 1
                                            zeros = "00"
                                          if bytenum == 2
                                            zeros = "0"
                                          if bytenum >= 3
                                            zeros = nil.to_s
                                          c.name = component.layer.name.concat(" - #{zeros}#{num}")
                                  Will keep you posted on further development...Cheers! 👍
                                  Right now it does it to all layer no matter if they are visible or not. But an option for only renaming visible layers could be done.
                                    renderiza
                                    With the code below the definition name is created.
                                    num = 0
                                        num=0
                                      groups.each do |g|
                                            num+=1
                                            if bytenum == 1
                                              zeros = "00"
                                            if bytenum == 2
                                              zeros = "0"
                                            if bytenum >= 3
                                              zeros = nil.to_s
                                        num=0
                                            num+=1
                                            if bytenum == 1
                                              zeros = "00"
                                            if bytenum == 2
                                              zeros = "0"
                                            if bytenum >= 3
                                              zeros = nil.to_s
                                            #c.name = component.layer.name.concat(" - #{zeros}#{num}")
                                            c.definition.name = component.layer.name.concat(" - #{zeros}#{num}")
                                    Will check it out indeed.
