    [req]rename objects with name of the layer
    16 Posts 3 Posters 7.2k Views 3 Watching
    • renderizaR Offline
      renderiza
      The code below solves the issue mentioned above about the numbers...
      model = Sketchup.active_model
      ents = model.active_entities
      groups = ents.grep(Sketchup;;Group)
      components = ents.grep(Sketchup;;ComponentInstance)
      num = 0
      groups.each do |group|
        group.name = nil.to_s
        if group.name == nil.to_s
          num=0
        groups.each do |g|
          if group.layer.name == g.layer.name
            if g.name == nil.to_s
              num+=1
              g.name = group.layer.name.concat(" - #{num}")
      components.each do |component|
        component.name = nil.to_s
        if component.name == nil.to_s
          num=0
        components.each do |c|
          if component.layer.name == c.layer.name
            if c.name == nil.to_s
              num+=1
              c.name = component.layer.name.concat(" - #{num}")
      The code uses numbers like this "door - 1" and not like this "door - 001". Do you need it to be like :door - 001" or is it fine like it is?
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • bagateloB Offline
        bagatelo
        Thanks! Thanks! Thanks!
        I like "door - 001"...
        Can you code this to add some option in some menu?
        And I also like to know if we can do it in the whole model or only visible layers....
        Thanks very much!
          renderiza
          Any suggestions for what should be the name of the plugin?
          Below are potential names...
          • Name by Layer
          • Rename by Layer
          • Entities Name by Layer
          • [Re]Name
          • Renamer
          • bagateloB Offline
            bagatelo
            [Re] name
            I think you could create something that rename numerous things, such as materials, components, Layers, etc ...
            "Central [Re] name"
            http://sketchucation.com/forums/viewtopic.php?f=323&t=47234
            http://sketchucation.com/forums/viewtopic.php?f=323&t=53329
              renderiza
              @bagatelo said:
              [Re] name
              "Central [Re] name"
              Really like that idea and the name "[Re]Name" is very fitting. But since that idea is more ambitious its advised to work our way there little by little.
              Maybe starting with renaming groups & components by layer for now and making that into an extension by itself with a different name than "[Re]Name".
              We can name the extension "Rename by Layer". Here is a Logo for the plugin...Any feedback is welcome.
              http://s17.postimg.org/m6twx3ekv/Logo_Default.png
              I started working on making the extension with web-dialog and plan to keep you posted on further progress...cheers!
              • bagateloB Offline
                bagatelo
                Thanks for the work, friend.
                Very much appreciated.
                Your logo was very interesting.
                You could change the code to rename the definition name?
                The reason I asked this plugin is because I'm trying to use the plugin "Solid Quantify by TAK2HATA". It's a wonderful plugin, and I need something to easily modify the names of components. Note the attachment files.
                plugs.zip
                • bagateloB Offline
                  bagatelo
                  Look what I have when I try to execute the last code...
                  Cleared the editor
                  Running the code...
                  Done. Ruby says: Run aborted. Error: undefined method ‘bytesize’ for "1":String
                    dedmin
                    Great plugin! It would be useful to have "append layer name as prefix/suffix" to the component's name.
                      renderiza
                      Great idea! I saw this just about when I published the first version to Plugin Store but maybe for next update your suggestion will be added.
                      Here are some links for the plugin;
                      SketchUp Plugins | PluginStore | SketchUcation
                      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                      (sketchucation.com)
                      http://sketchucation.com/forums/viewtopic.php?f=323&t=54165
                      Note: Something important that I noticed about definition names is that if you have 2 entities which are component instances they can't have different definition names.
                      For example;
                      Will not be named like below;
                      Layer: Door
                      component instance#1 definition name = Door - 001
                      component instance#2 definition name = Door - 002
                      component instance#3 definition name = Door - 003
                      component instance#4 definition name = Door - 004
                      They will be name like this;
                      component instance#1 definition name = Door - 004
                      component instance#2 definition name = Door - 004
                      component instance#3 definition name = Door - 004
                      Remember that its a rule that they must be the same. The numbers for definition name will only serve to display the total amount.
                      Cheers! 👍
                        dedmin
                          renderiza
                          Cleared the editor
                          Running the code...
                          This was an error on my part by using bytesize’ method which I will change to 'length' so it will work. Will try to update all the code example above to eliminate that issue.
                          I also published the plugin as an extension on Plugin Store as 'Rename by Layer' here is the link... http://sketchucation.com/resources/pluginstore?pln=RND_Renamer_v1.0.0
                          Also I made another topic here for future updates and stuff... http://sketchucation.com/forums/viewtopic.php?p=490834#p490834
                          Any feedback about the plugin will be great so I know that to fix on next update...Cheers! 👍
                            renderiza
                            I will eventually make an extension plugin with web-dialog that offers some options for the user. For now the code bellow displays the numbers like you suggested.
                            num = 0
                                num=0
                              groups.each do |g|
                                    num+=1
                                    bytenum = num.to_s.length
                                    if bytenum  == 1
                                      zeros = "00"
                                    if bytenum  == 2
                                      zeros = "0"
                                    if bytenum  >= 3
                                      zeros = nil.to_s
                                    g.name = group.layer.name.concat(" - #{zeros}#{num}")
                                num=0
                                    num+=1
                                    if bytenum == 1
                                      zeros = "00"
                                    if bytenum == 2
                                      zeros = "0"
                                    if bytenum >= 3
                                      zeros = nil.to_s
                                    c.name = component.layer.name.concat(" - #{zeros}#{num}")
                            Will keep you posted on further development...Cheers! 👍
                            Right now it does it to all layer no matter if they are visible or not. But an option for only renaming visible layers could be done.
                              renderiza
                              With the code below the definition name is created.
                              num = 0
                                  num=0
                                groups.each do |g|
                                      num+=1
                                      if bytenum == 1
                                        zeros = "00"
                                      if bytenum == 2
                                        zeros = "0"
                                      if bytenum >= 3
                                        zeros = nil.to_s
                                  num=0
                                      num+=1
                                      if bytenum == 1
                                        zeros = "00"
                                      if bytenum == 2
                                        zeros = "0"
                                      if bytenum >= 3
                                        zeros = nil.to_s
                                      #c.name = component.layer.name.concat(" - #{zeros}#{num}")
                                      c.definition.name = component.layer.name.concat(" - #{zeros}#{num}")
                              Will check it out indeed.
