    [req]rename objects with name of the layer
    16 Posts 3 Posters 7.1k Views 3 Watching
    • bagateloB Offline
      bagatelo
      [Re] name
      I think you could create something that rename numerous things, such as materials, components, Layers, etc ...
      "Central [Re] name"
      http://sketchucation.com/forums/viewtopic.php?f=323&t=47234
      http://sketchucation.com/forums/viewtopic.php?f=323&t=53329
      • renderizaR Offline
        renderiza
        @bagatelo said:
        [Re] name
        "Central [Re] name"
        Really like that idea and the name "[Re]Name" is very fitting. But since that idea is more ambitious its advised to work our way there little by little.
        Maybe starting with renaming groups & components by layer for now and making that into an extension by itself with a different name than "[Re]Name".
        We can name the extension "Rename by Layer". Here is a Logo for the plugin...Any feedback is welcome.
        http://s17.postimg.org/m6twx3ekv/Logo_Default.png
        I started working on making the extension with web-dialog and plan to keep you posted on further progress...cheers!
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        • bagateloB Offline
          bagatelo
          Thanks for the work, friend.
          Very much appreciated.
          Your logo was very interesting.
          You could change the code to rename the definition name?
          The reason I asked this plugin is because I'm trying to use the plugin "Solid Quantify by TAK2HATA". It's a wonderful plugin, and I need something to easily modify the names of components. Note the attachment files.
          plugs.zip
          • bagateloB Offline
            bagatelo
            Look what I have when I try to execute the last code...
            Cleared the editor
            Running the code...
            Done. Ruby says: Run aborted. Error: undefined method ‘bytesize’ for "1":String
              dedmin
              Great plugin! It would be useful to have "append layer name as prefix/suffix" to the component's name.
                renderiza
                Great idea! I saw this just about when I published the first version to Plugin Store but maybe for next update your suggestion will be added.
                Here are some links for the plugin;
                SketchUp Plugins | PluginStore | SketchUcation
                SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                (sketchucation.com)
                http://sketchucation.com/forums/viewtopic.php?f=323&t=54165
                Note: Something important that I noticed about definition names is that if you have 2 entities which are component instances they can't have different definition names.
                For example;
                Will not be named like below;
                Layer: Door
                component instance#1 definition name = Door - 001
                component instance#2 definition name = Door - 002
                component instance#3 definition name = Door - 003
                component instance#4 definition name = Door - 004
                They will be name like this;
                component instance#1 definition name = Door - 004
                component instance#2 definition name = Door - 004
                component instance#3 definition name = Door - 004
                Remember that its a rule that they must be the same. The numbers for definition name will only serve to display the total amount.
                Cheers! 👍
                  dedmin
                    renderiza
                    Cleared the editor
                    Running the code...
                    This was an error on my part by using bytesize’ method which I will change to 'length' so it will work. Will try to update all the code example above to eliminate that issue.
                    I also published the plugin as an extension on Plugin Store as 'Rename by Layer' here is the link... http://sketchucation.com/resources/pluginstore?pln=RND_Renamer_v1.0.0
                    Also I made another topic here for future updates and stuff... http://sketchucation.com/forums/viewtopic.php?p=490834#p490834
                    Any feedback about the plugin will be great so I know that to fix on next update...Cheers! 👍
                      renderiza
                      I will eventually make an extension plugin with web-dialog that offers some options for the user. For now the code bellow displays the numbers like you suggested.
                      model = Sketchup.active_model
                      ents = model.active_entities
                      groups = ents.grep(Sketchup;;Group)
                      components = ents.grep(Sketchup;;ComponentInstance)
                      num = 0
                      groups.each do |group|
                        group.name = nil.to_s
                        if group.name == nil.to_s
                          num=0
                        groups.each do |g|
                          if group.layer.name == g.layer.name
                            if g.name == nil.to_s
                              num+=1
                              bytenum = num.to_s.length
                              if bytenum  == 1
                                zeros = "00"
                              if bytenum  == 2
                                zeros = "0"
                              if bytenum  >= 3
                                zeros = nil.to_s
                              g.name = group.layer.name.concat(" - #{zeros}#{num}")
                      components.each do |component|
                        component.name = nil.to_s
                        if component.name == nil.to_s
                          num=0
                        components.each do |c|
                          if component.layer.name == c.layer.name
                            if c.name == nil.to_s
                              num+=1
                              if bytenum == 1
                                zeros = "00"
                              if bytenum == 2
                                zeros = "0"
                              if bytenum >= 3
                                zeros = nil.to_s
                              c.name = component.layer.name.concat(" - #{zeros}#{num}")
                      Will keep you posted on further development...Cheers! 👍
                      @bagatelo said:
                      And I also like to know if we can do it in the whole model or only visible layers....
                      Right now it does it to all layer no matter if they are visible or not. But an option for only renaming visible layers could be done.
                        renderiza
                        With the code below the definition name is created.
                        num = 0
                            num=0
                          groups.each do |g|
                                num+=1
                                if bytenum == 1
                                  zeros = "00"
                                if bytenum == 2
                                  zeros = "0"
                                if bytenum >= 3
                                  zeros = nil.to_s
                            num=0
                                num+=1
                                if bytenum == 1
                                  zeros = "00"
                                if bytenum == 2
                                  zeros = "0"
                                if bytenum >= 3
                                  zeros = nil.to_s
                                #c.name = component.layer.name.concat(" - #{zeros}#{num}")
                                c.definition.name = component.layer.name.concat(" - #{zeros}#{num}")
                        Will check it out indeed.
