    Is it possible to do something like this with SU?
    6 Posts 2 Posters 728 Views 2 Watching
      decumano
      So, I saw this video on TV and I would like to realize something similar... is it possible with SU? If it is, could you suggest to me a tutorial or a video where I can see something done with SU?
      Thank you all
      look at 24:00
        http://sketchucation.com/shop/extensions/220-keyframe-animation
          decumano
          Well! Thank you,but I have 2 questions for you (I' using the trial version before purchasing it):
          1 - I had some problem saving scenes, some objects turn back in the previous position and I need to save scenes 2 or 3 times, am I the first with this problem?
          2- Most important problem. The animation has a low quality, expecially on the edges, but I don't find a panel with quality settings... (except frames) maybe is not a problem of keyframe animation extension but of all SU scene animation settings...?
          can you help me?
            decumano
            Can someone help me?
            Please I need...
              Plugin works fine. Export still images at hi-res with AA off then post-pro them.
              Nested animation is explained in the help pdf with the tool
                decumano
                Well Rich O Brien, thank you!
                I'm going to export still images without Anti Aliasing
                Thanks!
                ...even if I cannot find anything about nested animation on th help...
