    Floor Generator Plugin for Sketchup?
    13 Posts 8 Posters 13.6k Views 8 Watching
    • N Offline
      numerobis
      I don't know if something like this already exists for Sketchup, but i think this would be a very useful one for all archviz people...
      http://www.cg-source.com/floorgenerator.php
      Using Floor Generator Script by Bertrand Benoit - 3D Architectural Visualization & Rendering Blog
      Ronen Bekerman - 3D Architectural Visualization & Rendering Blog (www.ronenbekerman.com)
      Not sure how the multitexture thing could be solved but maybe simply by using various sketchup materials.
      I don't know how difficult it would be to do something like this for sketchup but when i look at all the incredible existing plugins this looks like a "relatively easy" one for me... 💚
      • renderizaR Offline
        renderiza
        That would be really cool to have in SketchUp.
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        • KrisidiousK Offline
          Krisidious
          http://oob-su.com/
          Create 3D complex layouts in SketchUp
          Apply layout parameters to different faces
          Set colors, dimensions and spaces between elements of the layout
          Get number of elements (including re-used chutes)
          Re edit or undo layouts
          By: Kristoff Rand
          • N Offline
            numerobis
            Not bad... i didn't know this one.
            But it looks like it is lacking some the most important features of floorgenerator like bevel, random materials by element, texture coordinates and random rotation/offset.
            ...and $59 for this limited plugin 😮 😆
              Krisidious
              She's still working on it. And open to suggestions. She'll be adding stone work soon.
              By: Kristoff Rand
              • mitcorbM Offline
                mitcorb
                I am not familiar with the term "chutes" in this context?
                  Krisidious
                  I wondered that too... But figured it was those openings in the middle of patterns.
                  By: Kristoff Rand
                  • mitcorbM Offline
                    mitcorb
                    Well, the author appears to be French, and it may have a specific connotation in that language. and maybe your suggestion is the meaning.
                      steph4130
                      Hi guys,
                      Thank you for your remarks about Oob plugin.
                      Chutes is a bad translation for "re-using cut parts" of elements.
                      Like in real life, if you need a 1 m siding to finish a line, you won't cut a new 3 meters one but check in the cut sidings if you have 1 m part.
                      These cut parts are named chutes in French, do you know an appropriate translation?
                      Concerning plugin price I propose a special price for autumn and will probably keep this new price after that.
                      Kind regards, Stéphane.
                      • mitcorbM Offline
                        mitcorb
                        Hi, Stepháne:
                        Thanks for clearing up the term "chutes". It is not a bad translation, it is a customary term. A chute as I understand it is a channel down which objects are guided. The objects could be materials guided away from the cutting equipment.
                        In my experience, we would call them "cut-off(s)", "fall-off(s)", scraps, or leavings, or remainders. So maybe your term is more efficient. 👍
                        • pbacotP Offline
                          3d would be nice, (say a custom user made object that might need to be within size parameters to be stretched). To have things like brick or siding that actually has profile.
                          • jolranJ Offline
                            jolran
                            Anything dealing with custom made 3d pattern will have have to to some kind of boolean or intersect.
                            Sketchups API methods for doing thoose kind of things on a large entities Collection is just to slow and unpredictable on detailed meshes..
                            In fact it doesent really have to be detailed. A simple quadface intersecting near the edge-border of a face could cause trouble.
                            Been dabbeling quite a bit with that for Hatchfaces.
                            The best solution would probably be to build premade patterns library(like it looks like Stepháne is doing) and draw them within face boundries.
                            Easier said the done..
                              delowarhossain Newcomers
