    Floor Generator Plugin for Sketchup?
    13 Posts 8 Posters 13.9k Views 8 Watching
    • KrisidiousK
      Krisidious
      http://oob-su.com/
      Create 3D complex layouts in SketchUp
      Apply layout parameters to different faces
      Set colors, dimensions and spaces between elements of the layout
      Get number of elements (including re-used chutes)
      Re edit or undo layouts
      By: Kristoff Rand
      • N
        numerobis
        Not bad... i didn't know this one.
        But it looks like it is lacking some the most important features of floorgenerator like bevel, random materials by element, texture coordinates and random rotation/offset.
        ...and $59 for this limited plugin 😮 😆
        • KrisidiousK
          Krisidious
          She's still working on it. And open to suggestions. She'll be adding stone work soon.
          By: Kristoff Rand
          • mitcorbM
            mitcorb
            I am not familiar with the term "chutes" in this context?
            • KrisidiousK
              Krisidious
              I wondered that too... But figured it was those openings in the middle of patterns.
              By: Kristoff Rand
              • mitcorbM
                mitcorb
                Well, the author appears to be French, and it may have a specific connotation in that language. and maybe your suggestion is the meaning.
                  steph4130
                  Hi guys,
                  Thank you for your remarks about Oob plugin.
                  Chutes is a bad translation for "re-using cut parts" of elements.
                  Like in real life, if you need a 1 m siding to finish a line, you won't cut a new 3 meters one but check in the cut sidings if you have 1 m part.
                  These cut parts are named chutes in French, do you know an appropriate translation?
                  Concerning plugin price I propose a special price for autumn and will probably keep this new price after that.
                  Kind regards, Stéphane.
                  • mitcorbM
                    mitcorb
                    Hi, Stepháne:
                    Thanks for clearing up the term "chutes". It is not a bad translation, it is a customary term. A chute as I understand it is a channel down which objects are guided. The objects could be materials guided away from the cutting equipment.
                    In my experience, we would call them "cut-off(s)", "fall-off(s)", scraps, or leavings, or remainders. So maybe your term is more efficient. 👍
                    • pbacotP
                      3d would be nice, (say a custom user made object that might need to be within size parameters to be stretched). To have things like brick or siding that actually has profile.
                      • jolranJ
                        jolran
                        Anything dealing with custom made 3d pattern will have have to to some kind of boolean or intersect.
                        Sketchups API methods for doing thoose kind of things on a large entities Collection is just to slow and unpredictable on detailed meshes..
                        In fact it doesent really have to be detailed. A simple quadface intersecting near the edge-border of a face could cause trouble.
                        Been dabbeling quite a bit with that for Hatchfaces.
                        The best solution would probably be to build premade patterns library(like it looks like Stepháne is doing) and draw them within face boundries.
                        Easier said the done..
                          delowarhossain Newcomers
                          @numerobis said:
                          I don't know if something like this already exists for Sketchup, but i think this would be a very useful one for all archviz people...
                          http://www.cg-source.com/floorgenerator.php
                          http://www.ronenbekerman.com/using-floor-generator-script-by-bertrand-benoit/
                          Not sure how the multitexture thing could be solved but maybe simply by using various sketchup materials.
                          I don't know how difficult it would be to do something like this for sketchup but when i look at all the incredible existing plugins this looks like a "relatively easy" one for me... 💚
