    Anyone know of a Plugin: open/ close a skp file and save jpg
    7 Posts 6 Posters 510 Views 6 Watching
    • Z Offline
      zzm
      I have 400 skp files and need to save a jpg of each one. I was looking for a plugin to open/ close each and save a jpg. It would be nice to adjust the resolution, but screen resolution works.
      • mitcorbM Offline
        mitcorb
        Do they each have a saved Scene, or would you accept a default view-last camera position. Seems like you would need to go into each file and set this up? Or, what if thumbnail images were adjustable?
        • renderizaR Offline
          renderiza
          Really like this idea since it will help you find what model is inside a file without the need of opening SketchUp file.
          If I find a way to do this will let you know...cheers!
          [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
            jpalm32
            Why not use XnviewMP? What am I missing?
            Saves and shows all SKP & SKB.
              Aerilius
              I once had something similar setup, whenever a file was opened a plugin would save a large thumbnail with alpha channel into a folder. However it wasn't a batch script (to do all at once).
              You would need to iterate through files in a folder and open one after the other using the API method. I assume all the needed API methods are synchronous (otherwise you would need observers).
              • Z Offline
                zzm
                Plugin would open each skp and save the current view. No scene tabs, just open/ close and save a jpg.
                  Wouldn't Mystic Thumbs or MooTools 3D Browser do this easier?
