    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 310.0k Views 110 Watching
    • Bob JamesB Offline
      Bob James
      Still some problems (for me) with this amazing plugin:
      1. Turn off group
      2. Turn on one layer in the group
      3. All of the layers in the group turns on
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        That's not a problem, that's a feature. πŸ˜„
        Showing a layer in an hidden group turns this group on. That's just the way it works.
        • H Offline
          huckrorick
          I agree with Bob James. My preference would be when I turn on a single layer within a group that only that layer comes on. If I click on the group, then I would want all layers to come on. Of course, this is just a matter of preference for working style, but it is the way I would like it. Here is an example of how it would work for me: I have turned off a group. If I want it back on then I click on the group. If I don't want it all back on, but just one layer, then I would like to click on that layer. The way it is now I click on that layer and then have to unclick all the other layers. If there are a lot of them, then this becomes a little tedious.
          Just my preference.
          This is a terrific app.
          • jgbJ Offline
            jgb
            I totally agree with Huckrorick. πŸ‘ πŸ‘
            jgb
              jiminy-billy-bob
              The thing is that a group must active for you to see what's inside. So when you click on a layer inside an hidden group, this group must me activated. And if it's activated, every "hidden by group" (eye grayed out) layers inside it are activated as well.
              But I will add a shortcut to isolate a layer (in its local group, and another shortcut for all the way down to the root)
                Bob James
                Great!
                By the way: I still have the problem with retaining layers in scenes. Any progress on this?
                  jiminy-billy-bob
                  What do you mean "retaining layers" ?
                    Bob James
                    A scene is created with a set of layers active.
                    Go to another scene and add or remove layers that are active in that second scene
                    Go back to the first scene and the layers originally active in that scene are no longer active.
                    I reported this several weeks ago. I had to stop using the plugin because of it. I loaded the 0.7 version recently and the problem came back as it was before.
                      jiminy-billy-bob
                      Really ? It was supposed to be fixed, and this to be an option... Did you do a clean install of the plugin ? Is the option checked ?
                        jiminy-billy-bob
                        New version 0.8 beta !
                        Changelog :
                        • Added ALT+click on layer visibility : Isolate layer
                        • Added CTRL+click on layer visibility : Isolate layer in its group
                        • Added SHIFT+click on layer visibility : Toggle all highlighted layers
                        • Added button to highlight selection's layer
                        • Added button to select highlighted layer's entities
                        • Fix copy/paste between instances
                        Download in the plugin store !
                          jiminy-billy-bob
                          New version 0.7 beta !
                          Changelog :
                          • Added a dark bar at the top to minimize/maximize the dialog
                          • Added CTRL+G : Group selected layers
                          • Added CTRL+SHIFT+G : Ungroup layers
                          • Added CTRL+A : Select all
                          • Added CTRL+E : Merge selected layers
                          • Added different color for groups
                          • Layer0 is now selectable
                          • Fix bug with sorted groups
                          • Potential fix for IE version bug
                          • bagateloB Offline
                            bagatelo
                            Can you reply the features of this plugin for 3dsmax to sketchup?
                            Attention Required! | Cloudflare
                            (www.scriptspot.com)
                              jiminy-billy-bob
                              What features exactly ? LP already allows to group and merge layers.
                              What do "Alternate Material", "Alternate Property", "Import of REZN8 LayerManager Information" exactly ?
                              • ElibjrE Offline
                                Elibjr
                                Wow, this plugin is really coming along! When you add the color functionality to the plugin. I will be able to use it exclusively. See as a developer and designer of buildings where renovation is the norm. Having a colored layer for existing work and a second color for work to be removed as well as a new work layer color is critical in developing the scope of a project long before you figure out materials. Thanks for the good work. The great aspect of your plugin would be to start off with the default color and only color the needed layers, but then anything put into that layer would have that color. This is a great checking system to make sure what you have created is in the correct layer. Thanks for your great work.
                                  jiminy-billy-bob
                                  Unfortunatly, I won't be able to add layer colors until the API is updated. There are some workaround, but they're just so heavy, I don't think that would be usable...
                                  In the meantime, layer colors still work in the default layers window.
                                    jiminy-billy-bob
                                    FYI, TT is currently helping me porting the plugin on OSX. Cheers to him ! πŸ˜„
                                    • marcorigamonti74M Offline
                                      marcorigamonti74
                                      Let me know when the plugin will be ready for OSX sistem!!!
                                      THANKS!!!!!!
                                      • nanolinN Offline
                                        nanolin
                                        Hello
                                        You can sort the list by alphabetical order of layers? . It can be added as an option?
                                        thanks
                                          db11
                                          Been patiently waiting for a functioning OSX version of this must-have plugin, so this is the best news I've heard in a long time!
                                          Any idea on the ETA?
                                            jiminy-billy-bob
                                            @nanolin said:
                                            Hello
                                            thanks
                                            Someone (maybe you ?) already suggested this. So it's on my todo list πŸ˜‰
                                            Nope. In the meantime, you guys can help by filling the issue tracker on the github projet : https://github.com/jiminy-billy-bob/Layers-Panel/issues?state=open
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 33
                                            • 34
                                            • 15 / 34
